How to enable Airplay on older Sonos devices with Airconnect
Hi all,
I have a Coreelec box - Beelink GT King, and it is always on, so I thought I could use it with my older Sonos speakers that don’t support Airplay. This can be done using the great software Airconnect (https://github.com/philippe44/AirConnect)
It is very easy to set up, and it can actually be used to activate Airplay for all upnp devices - and also Chromecast with a small change in scripts. I will only show setup for Sonos here.
This is the code to put into SSH on your Coreelec box:
Create a folder
mkdir /storage/airconnect/
cd /storage/airconnect/
Download Airconnect
wget https://raw.githubusercontent.com/philippe44/AirConnect/master/bin/airupnp-arm
Make file executable:
chmod +x airupnp-arm
Edit a new service
nano /storage/.config/system.d/airupnp.service
In the nano editor paste:
[Unit]
Description=AirUPnP bridge
After=network-online.target
Wants=network-online.target
[Service]
ExecStart=/storage/airconnect/airupnp-arm -l 1000:2000 -o S1,S3,S5,S9,S12,ZP80,ZP90,ZP100,ZP120 -Z
Restart=on-failure
RestartSec=30
[Install]
WantedBy=multi-user.target
Then exit by ctrl+X - save file
In the file I have defined that it should only look for older Sonos devices not already supporting Airplay with the “-o S1, …” command. You can leave that part out if you want all your upnp devices listed.
Sonos player model numbers:
Play:1 : S1, S12
Play:3 : S3
Play:5 gen 1: S5
PlayBar: S9
ZonePlayers: ZP80, ZP90 (Connect), ZP100, ZP120 (Connect:Amp)
Then in SSH enable the new service:
systemctl enable airupnp.service
And then start the service:
systemctl start airupnp.service
Your players will now be available in Airplay compatible devices with their name and a (+)
The service will start when you reboot now. You can always disable with:
systemctl disable airupnp.service
Enjoy Airplay
Works great but every time I reboot Kodi, I have to re enable the command
Hmm that is strange. Mine starts automatically every time I reboot.
Will this allow me use Sonos speakers as output ?
Yes, your Sonos will work as an Airplay speaker.
Okey mayby i missunderstood.
I wanted to use my sonos speakers as output from coreelec.
However i managed to get airconnect running as AirPlay proxy.
Is it possible to send the audio to Sonos speakers from coreelec ?
Henrik
