To enable retro player on corelec builds simply type the secret konomi code in on the home screen. as below…
I would recommend using a xbox 360 controller via the windows wireless adapter.
You will then get a extra menu on the home screen called games where you can add your rom source or install the rom collection browser to browse your existing roms.
Hope that helps someone.
Matt
