How to fix green screen issue with VIM3?
I installed the latest Android firmware (V191122) on my brand new VIM3 and then booted the latest stable CoreELEC (9.2.1) from USB. But this results in the infamous green screen issue. I though that was resolved some time ago?
Anyways, what versions Android/CE should I use to fix this?
It is resolved.
You have to edit your config.ini and uncomment “use_rgb_to_yuv=0”
Thanks! I had to set that value to 1 though for the green screen issue to resolve itself. Could this cause any issues (e.g. banding)?
