How to input and flash A95X F3 for help
Hello, everyone. I’m from China and I don’t know much English. This is what I translated using Google.
I have a TV box, the model is: A95X F3, 4gb and 32GB storage, can I flash CoreELEC directly, or what files should I replace?
Welcome.
thank you very much
Personally, I don’t think using the ceemmc tool first off is a good idea. I think you should install to a micro sd card or usb first. If you are then happy, by all means use the tool.
