I’m strugling with mounting internal storage on my A95x F3 Air box with;
mount -t ext4 /dev/mmcblk0 test/
which is failed.
And I’m also trying to find a way to mount my external hdd storage, but there’s seemingly no supportion for NTFS yet.
How can I do that…
I have a 64 Gb internal storage, whereas my external TF card is only 32 Gb. What a waste if i use only the external storage…
Sorry, mount: mounting /dev/mmcblk0 on /media/ failed: Invalid argument
I think that maybe the reason is the swap partition in this card, or something associated with the Android 9 system.
I have no idea.
vpeter
27 November 2020 11:51
#4
mmcblk0
is whole disk but you need to mount partition.
Try with mmcblk0pX
where X is number of required partition.
there are only
/dev/mmcblk0 /dev/mmcblk0boot0 /dev/mmcblk0boot1 /dev/mmcblk0rpmb
vpeter
27 November 2020 12:19
#6
Then you are out of luck. Probably.
system
closed
26 February 2021 18:19
#7
