i don’t have, i have gt mini
CoreELEC: ~ # ceemmc -h
-sh: ceemmc: not found
CoreELEC: ~ #
CoreELEC: ~ #
You need to use latest nightly as minimum for this feature.
This system uses the SD card to boot.
Thanks for the answer
I checked nightly and has a disadvantage, constantly displaying update.
This is not very pleasant
it certainly doesn’t speed things up
An SD disk image was made for easy installation.
The installation is started with the installemmcsystem command.
Entware and some remote and vfd conf have been integrated.
Details here..
Also available on old S905-912 boxes.
In that case you can wait for next stable soon…
Read the card for 2 seconds and then run from the eMMC. Boot time is 9 seconds.
Not enough space on Android data partition. Exiting!
Old version clean / vipe partition = Done
Thanks for the great work. I have a Beelink GT mini-A and everything went well. Installation fast and coreelec also faster.
Just a question- couldn’t the storage be split between Android and Corelec in emmc 20% for Android and 80% for Coreelec?
Yes, you can use the official ceemmc
tool for this on -NG devices.
Yes it can be.
With a 32GB eMMC, the 8GB droid will be 20GB for CE.
You must restore the original state.
Thank you very much, I just have a little problem with the translation. This also write via SSH?
Yes after SSH login.
Update on the android systems are with coreelec not possible…
so when I want to update android I hat do use usb burning tool. But then corelec is gone
Android OTA update.zip working.
Mhh mine was failed… but it was supercelerons ATV beta Build
CE kernel integrated boot manager.
Details here.
Yes! Another nice job from Emerson! Thank you!
Maybe the boot manager version could earn a new topic, this is for Android lovers too:)
Dear Everybody!
Because of the invisibility of this topic, I am finishing up my activity here.
You can continue reading about the topic here.
Google translator, translates quite well from Hungarian to English.
Have fun!
