Firstly before we begin i should highlight the fact that there is already a Tvheadend Server (and client) Kodi Addon created by the CoreELEC team, so if you aren’t interested in Docker then please use the Addon instead.
With that out of the way let’s list the reason why we might want to run Tvheadend Server as a Docker container:-
Control over version - You can dictate the version of Tvheadend you want, if you want latest stable, you can do that, if you want older builds, you can do that, if you want bleeding edge master commits, you can also do that, the choice is yours :-).
Platform and architecture agnostic - If you can install Docker on your host then you can run Tvheadend Server, the only pre-req is the Docker engine. What this means is you can move your Tvheadend config from different OS’s and even different Architectures without any loss of config, which is awesome!.
Step 1. So as mentioned above the first step is to get Docker installed, this can be done via the CoreELEC maintained Docker addon, to install it simply do a search for ‘docker’, and install. Once it’s installed you can confirm its working by SSHing into your host and then issue the command ‘docker info’.
Step 2. Decide which version of Tvheadend you want to run, this is best explained by clicking on the link below and going to the ‘Version Tags’ section:-
If you want to run a specific build then you can see the full list of all available tagged Docker images here:-
https://hub.docker.com/r/linuxserver/tvheadend/tags
Step 3. Now we know which version we want to run, we now need to create the Docker Container, this is done via the command line, so SSH in to your host and issue the following:-
mkdir -p /storage/.user/docker/config/tvheadend && \
docker run -d \
--name=tvheadend \
--restart unless-stopped \
--device /dev/dvb:/dev/dvb \
-e PUID=0 \
-e PGID=0 \
-e TZ=Europe/London \
-p 9981:9981 \
-p 9982:9982 \
-v /storage/.user/docker/config/tvheadend:/config \
-v /var/media/External/TV:/data \
linuxserver/tvheadend:release-4.2
Replacing any paths with appropriate values and the version you wish to run.
Step 4. You may find that the container actually starts before all TV tuners are detected and available, in order to work around this i have created a simple script to help with this scenario:-
#!/bin/bash
# script designed to make the starting of docker containers (particularly tvheadend)
# a little bit more robust, as detection of dvb adapters can be slow and thus cause
# a timeout and failure for the container to start.
docker_path="/storage/.kodi/addons/service.system.docker/bin/docker"
dvb_adapter_count=4
# wait for docker to be responsive
while [ $(systemctl is-active docker) != "active" ]; do
sleep 0.1s
done
# wait for dvb adapters to be present
while [ ! -d "/dev/dvb" ]; do
sleep 0.1s
done
# if number of adapters is less than the expected max amount (4) then we sleep to allow
# all available to be detected before starting the container.
if [ $(find /dev/dvb -mindepth 1 -maxdepth 1 -type d | wc -l) != "${dvb_adapter_count}" ]; then
sleep 10s
fi
# set container to auto restart (will cause it to auto start on boot) and then force
# start.
"${docker_path}" update --restart=always tvheadend ; "${docker_path}" start tvheadend
In order for the above script to auto run you need to call it from the auto start script, this is located at ‘/storage/.config/autostart.sh’, it may or may not exist, if it doesnt exist then create it as follows, else append the call line to the existing script:-
#!/bin/bash
# script to wait for all adapters to be present before running container
/storage/<name of the script above>
Step 5. So how you do you keep your Docker images up to date with any new releases you may be asking, this is achieved by using another Docker image which includes an application called ‘Watchtower’.
What this application does is it monitors ‘Docker Hub’ for changes, if a change is detected (as in a new image is built) then Watchtower will automatically pull the image down, stop and delete the existing container, and then re-create the container with the existing parameters.
To get Watchtower installed you simply perform the following, again from SSH on the host:-
mkdir -p /storage/.user/docker/config/watchtower && \
docker run -d \
--name=watchtower \
-v /var/run/docker.sock:/var/run/docker.sock \
-e WATCHTOWER_NOTIFICATIONS=email \
-e WATCHTOWER_NOTIFICATION_EMAIL_FROM=watchtower@gmail.com \
-e WATCHTOWER_NOTIFICATION_EMAIL_TO=fred.blogs@gmail.com \
-e WATCHTOWER_NOTIFICATION_EMAIL_SERVER=smtp.gmail.com \
-e WATCHTOWER_NOTIFICATION_EMAIL_SERVER_USER=fred.blogs@gmail.com \
-e WATCHTOWER_NOTIFICATION_EMAIL_SERVER_PASSWORD=mypassword \
containrrr/watchtower:arm64v8-0.3.3 --debug --interval 43200
Again replacing any paths, version and email details (if you want it to notify you of updates).
Please note you will see ‘docker pull’ notifications in kodi due to the Docker addon notifications, so please keep the --interval value to a reasonably high number or you will be bombarded with notifications.
