@Portisch
I found the service.hyperion.ng folder at /.kodi/addons.
Is that the right one and which files or content do I have to copy into it?
Here is the link from the PR Hyperion PR Build
At the moment I have no problems with 2.0.0 alpha3. I only want the latest PR from @Paulchen-Panther to regulate my digital Grabber. But I donât know how install at CoreElec.
[hyperiond AMLOGICGRABBER] (INFO) FB mode
[hyperiond LEDDEVICE] (ERROR) An I/O error occurred when a resource becomes unavailable, e.g. when the device is unexpectedly removed from the system.
[hyperiond LEDDEVICE] (ERROR) Device disabled, device 'adalight' signals error: 'Rs232 SerialPortError, see details in previous log lines!'
[hyperiond LEDDEVICE] (DEBUG) (ProviderRs232.cpp:152:closeDevice()) Close UART: /dev/ttyACM0
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) LED device: disabled
On resume from suspend the LED device getâs disabled because of the IO error. This is a different error handling like before. Before the LED device got closed and reopened on IO error. Now it remain disabled.
When I go to the web interface I can enable the LED device again after system resume and they work again like before suspend.
You can send the CoreELEC device by systemctl suspend into suspend and just resume it by the IR remote. I have a Arduino UNO clone connected by USB.
I will have a look.
Quickly looking at the proposed patch, it will not address the root cause. It will more create problems as the general infrastructure of timer etc. are not properly closed.
Seem we need to differentiate between real errors and no error scenarios. The real ones are to put the devices âIn Errorâ.
When I refactored the code, I assumed that errors logged are real ones which need to be resolved before reopening a device. Let me review the code again.
I may need your support to differentiate between the scenarios.
Just thinkingâŠ
Shouldnât the scenario not be fixed in a way that after resume the device is triggered to be switched on again? switch on will try to reopen the device. Via remote control you can simulate this trigger manually.
The would avoid any polling in an undefined Hyperion environmentâŠ
I tested now the patch and in general itâs working, LEDs getting switched off and are working after resume from suspend.
But now I see the issue what have been there already before this feature got deactivated in hyperion.ng: it workâs only every second supend/resume cycle or even only once!?
I just tried it and the signal get sent every time by this script:
#!/bin/sh
case "$1" in
pre)
# <do something on suspend>
pid=$(pgrep hyperiond)
echo "+++++++++++++ pre pid: $pid" >> /storage/.kodi/temp/hyperion.power
if [ -n "$pid" ]; then
kill -SIGUSR1 $pid
fi
post)
# <do something on resume>
echo "+++++++++++++ post pid: $pid" >> /storage/.kodi/temp/hyperion.power
kill -SIGUSR2 $pid
fi
esac
Result (I did 3 times suspend & resume):
+++++++++++++ pre pid: 4603
+++++++++++++ post pid: 4603
So Kodi & kernel send the signal to the hyperiond pid.
This is the hyperion log (I added a debug print at the signal handler in main.cpp):
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) LED device: enabled
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:238:setInputImage()) Priority 250 is now inactive
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:333:setCurrentTime()) Set visible priority to 254
[hyperiond MAIN] (INFO) +++++++++++++ enter signum: 12
[hyperiond MAIN] (INFO) +++++++++++++ signum == SIGUSR2
[hyperiond MAIN] (INFO) +++++++++++++ _hyperion != nullptr
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:64:handleCompStateChangeRequest()) Enable Hyperion, recover previous component states
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) Hyperion: enabled
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) Smoothing: enabled
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) Blackborder detector: enabled
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) Framegrabber: enabled
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:238:setInputImage()) Priority 250 is now active
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:333:setCurrentTime()) Set visible priority to 250
[hyperiond LEDDEVICE] (ERROR) Device disabled, device 'adalight' signals error: 'Timeout on write data to /dev/ttyACM0'
[hyperiond WEBSOCKET] (DEBUG) (WebSocketClient.cpp:204:sendClose()) send close: 1000
[hyperiond WEBSOCKET] (DEBUG) (WebSocketClient.cpp:30:WebSocketClient()) New connection from ::ffff:192.168.1.109
[hyperiond WEBSOCKET] (DEBUG) (JsonAPI.cpp:107:handleInstanceSwitch()) Client '::ffff:192.168.1.109' switch to Hyperion instance 0
[hyperiond WEBSOCKET] (DEBUG) (JsonAPI.cpp:1119:handleLoggingCommand()) log streaming activated for client ::ffff:192.168.1.109
[hyperiond WEBSOCKET] (DEBUG) (JsonAPI.cpp:1128:handleLoggingCommand()) log streaming deactivated for client ::ffff:192.168.1.109
[hyperiond MAIN] (INFO) +++++++++++++ enter signum: 10
[hyperiond MAIN] (INFO) +++++++++++++ signum == SIGUSR1
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:51:handleCompStateChangeRequest()) Disable Hyperion, store current component states
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) Hyperion: disabled
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) Smoothing: disabled
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) Blackborder detector: disabled
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:255:clearInput()) Removed source priority 250
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) Framegrabber: disabled
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:158:registerInput()) Register new input 'System/GRABBER' with priority 250 as inactive
[hyperiond AMLOGICGRABBER] (INFO) VPU mode
[hyperiond WEBSOCKET] (DEBUG) (WebSocketClient.cpp:30:WebSocketClient()) New connection from ::ffff:192.168.1.5
[hyperiond WEBSOCKET] (DEBUG) (JsonAPI.cpp:107:handleInstanceSwitch()) Client '::ffff:192.168.1.5' switch to Hyperion instance 0
[hyperiond WEBSOCKET] (DEBUG) (JsonAPI.cpp:1119:handleLoggingCommand()) log streaming activated for client ::ffff:192.168.1.5
It worked only once, after second suspend the LEDs remain off, even when the log says VPU mode on.
It is working if I try it only on a debug device with no Rs232 client connected. Then every time the signals are received.
So after latest update to Hyperion.NG v. 103 from CoreElec repo my Hyperion Control addon stopped working. I have updated the addon to the latest version 1.0.1 and disabled API Authentication in my Hyperion web interface.
It doesnât seem like itâs doing anything at all. Iâm trying to disable Hyperion in Kodi menu. Besides that, everything is working fine. Logs also donât show what could be wrong. Any help is appreciated.
