I don’t know why it’s working, but since the box has 1GB of RAM, you shouldn’t use a 2g DTB.
Also I see that on the board there are 4x256mb memories but I do not understand and also coreelec and previus android nougat visualize 2gb of ram.We wait to see if anyone has any ideas about it. I tried two files: gxl_p212_1g_nand.dtb and gxl_p212_1g.dtb but coreelec does not start. It stops at the Amlogic logo.I have attached the file that works.
dtb.img (39.8 KB)
My X92 box works OK with 3 different dtb files…
Maybe they have common features but a 2gb dtb file that works on hardware with 1gb is rather strange. Also because the memory mapping is not performed by the parameters contained in the DTB file but are extracted from the device itself, perhaps in the kernel. I honestly do not know what to really think. If the device really only has 1gb of ram but the dbb file for 1gb does not work I do not see many ways out. As I wrote before, the 1gb db files I tried do not work.
The memory IC is marked 256X16DDR3, no manufacturer, no real chipmarking, so seems to be cheap spotmarket buy.
Anyhow, 256Mbit x16 / 8bit = 512MByte per IC
There are four ICs, so total memory should be 2GByte
For the Flash, there seems no additional managing IC on the bottomside, so it must be connected directly to the CPU, with some special code in Android for managing it. No chance to get it running with CE
Anyway, I have the same pèroblema to re-create the message that I can not find a Rome that is compatible with the device. When I upload from usb the upload stops at 4%. I think it’s due to the same problem. One last information .Fing for android sees it as a Minix Player and the manufacturer on the MAC is “ICA”. From a brief search it should be the one on this video:
Finding an Android recovery image for that box may get challenging, I cannot help you on that.
But why don’t you keep the box running CE from SDcard?
As far as I understood, you had CE running. So you just ignore the NAND, and may use gxl_p212_2g.dtb…
This is exactly why install to internal is not recommended. If it breaks it has already trashed your android partitions. When thatb happens you need oneb ROM out of thousands on the net and if it turns out yours is a no name fake clone i wish you luck finding a recovery rom. On top of this most roms are update images which are incomplete for recovery purposes.
Do you wonder why no one will help you dig out of the hole you have fallen into.
DONT DO IT UNLESS YOU KNOW HOW TO RECOVER IN ADVANCE.
It’s what I’m doing. I would like to use CE on nand because it is faster. I can use it like that but it’s not the same thing.
I have to make a clarification. currently the device does not work NOTHING on nand but not because I was wrong something. Simply the device as a result of a power surge has corrupted the data contained in the nand. The nand works but the overvoltage has canceled it. Despite this I can not in any way restore any android rom as during upload it stops at 4%. Currently the only evolution for me is to use it on SD. With this I think I have answered your question.
It stops at 4% because it is the wrong rom. This is typical behaviour for these boxes. Also there are multiple versions of amlogic burn tool and you may find value in trying them all. Basically expect a long process of trial and error before you get your box back. It took me many days the first few times and i made certain to save the correct software and rom when i did. It was a multi stage process on my old s812 box involving loading one rom and then another over the top of the first. Only then could i get libreelec loaded.
You have a box that works off SD, i would be happy.
@rawrow, if you want to use internal storage for Kodi you should follow the guide presented in the comment below. You’re on your own if you want to restore Android etc, however, look for information over at Freaktab if you really want to try to figure it out. As Shoog mention it’s a time consuming task with allot of trial and error…
Its not faster at all.
It’s posts like these that make the team want to remove support for install to internal for everything other than dev boards, its certainly brought back for me how much I hate it everytime I see posts like this.
