Java for BD-J menus
in the meantime I have not yet thanked you publicly for the hard work you do, it is really a great thing and much appreciated.
I’d like to ask you one more thing: I’d like to try to compile by hand the same release you made to read bluerays, can I ask you exactly the steps you did? Or if you’d like, could you write a mini tutorial so that I can experiment without bothering you every time?
thank you very much
This is my branch: https://github.com/vpeter4/CoreELEC/commits/bd-j-01
git clone https://github.com/vpeter4/CoreELEC -b bd-j-01 CoreELEC.19.bd-j-01
cd CoreELEC.19.bd-j-01
make
Thanks!
I’ll try it!
@vpeter , I was able to get my Mint20 desktop playing bluray with vlc and libmmd from makemkv along with the other packages needed.
But I have not been able to get it to play an ISO of a bluray. Either directly or after mounting it. Is your CE image able to do that?
I only have few ISO files. But i didn’t test it with this new version.
@vpeter
I have fixed chapter skip and seeking in bluray and bluray uhd with popup menus titles without the need for the user to press ctrl+shift+m or the popup key to toggle it on and off.
Please, add it to your build so we can enjoy it on coreelec
Tar file with the patch above: https://drive.google.com/file/d/10dZrGpgmuisHeT7z_km05dyqKuM2wvAl/view?usp=sharing
Sorry to bother you, vpeter, but can you apply this patch on non -ng Leia builds as well?
Or is it not possible?
I put both images in libbluray-1.2.0 – Google Drive
Silly question:
If I want to add this to my CE installation (leia based). What do I need to do/get? I use the generic NG builds.
My changes: https://github.com/vpeter4/CoreELEC/commits/9.2.5-bd
Hi @vpeter,
Is this fully functional alteady cause there is an bdjava addon in the CE nightly addons.
This version has some newer libraries and support menus better.
Thnx so what version to use? The CE repo version?
@vpeter how to install this in matrix nightly?
Hi, I’m using your version of Corelec because I have lots of BD Isos on my NAS. I works really well! Thanks for that! There are some disks/menus that refuse to load (I had no luck i.e. with “A Bug’s Life” and “Payback”) but that’s ok in my book.
What I’,m wondering is if your changes will get merged into the master branch at one point? I’ve read the discussion about the large JRE install, but that can be installed as a plugin for whoever wants it. What are your thoughts about that?
It is not just addon but you need my image and my addon: https://drive.google.com/drive/folders/1kqShTEhQ2lYCEZ8VAiih8jfhrOq18BS0?usp=sharing
Sure, when Kodi will bump the libraries my version will not be needed anymore.
I saw that the Kodi team has released the final Matrix, I wanted to ask you if by chance you have already made your Vpeter’s release with blueray addon and if you could in case link it to me
and thank you very much for all your hard work
Just wait few days for final CE release and then I will build it again.
CE 9.2.6 released,can you build new version,thank you very much!
