Here it is libbluray-1.2.0 â Google Drive
Hi @vpter,
sorry for the dumb question but what is the difference between ng-arm and arm? (for use with Odroid N2+)
thanks and sorry again eh
The difference is the same as with official CE images
For Odroid N2+ you need ng version.
Hi @vpeter
I wanted to ask you kindly if in the final version (https://github.com/CoreELEC/CoreELEC/releases) there are already your patches or if I have to wait for the vpeterâs version
Does this already include the new version (1.2.1) of libbluray?
Here is the CE19 with libbluray 1.2.1: libbluray-1.2.1-ce-19 â Google Drive
Hi @vpeter thank you for this build.
I installed your addon also but when enabling show bluray menu it complanes that java is not installed.
What to do next when installing addon and your build ?
Reboot after installing addon doesnât help i also tried the java addon on the CE repo but i get the same error to when enabling bluray menu.
Can you confrim the addon works with your build?
Thanks!
Hi @vpeter
I tried last night and today with your latest release but the bluerays donât work, it doesnât load the iso.
I leave you the logs for any eventuality
Seems libbluray 1.2.1 doesnât play nice: I could play 1 out of 5 ISO samples I have. So it is no-go.
But I see here windows version but I donât see sources: https://www.xbmcbrasil.net/thread-4216-page-4.html
As I wrote I donât have time to look more into this. Sorry. If someone finds some git source where someone use Kodi 19 with libbluray 1.2.1 let me know and I will try to use it.
But even libbluray 1.2.0 doesnât work. Need to look why.
no hurry, I know youâre really very very busy lately, but I wanted to ask you if when you have time you could make a test with the nightly version because on the normal release I have the problem that my device (N2+) remains stuck on the resolution 1920*1080 (instead yesterday I tried the nightly and it works even the 4K)
thanks and have a nice Saturday!
Ciao
yes,vperter version can not play UHD bd-j menus,but IT can paly hd bd-j menus wellă
Hi Vpeter, I see your last post link with two files.
Tools.jre.zulu
And your corelec with libbluray 9.2.2
First I had to create the corelec usb disk with your file, and after this I had to install this addon tools.jre.zulu? To work properly?
It is my first install with libbluray, I used a old corelec without this plugin.
Thanks the attention.
Yes, use my image and addon.
But it doesnât work properly in CE 19. I will look into it next days when I expect some free time from work.
I keep trying (http://tools.jre.zulu-19.0.100.zip/) with Matrix, and few BDMV/ISO is work, but most not. So, iâll be very happy if you solve this problem, because I like to watch the full menu as much as I can. I am waiting patiently (but impatiently :)) Of course thank you for your efforts!
I donât know what is wrong but I canât get BR menus working. I though there is something wrong with update thatâs why I use all the files from 9.2.5 version. And still nothing. Iâm little mad
BR menus are working 99% for me, latest 19 nightly.
Even the UHD Michael Schenkerâs Temple of Rock: On a Mission - Live in Madrid 4K
Menu works nicely but the result is black screen.
Also for uhd blurayâs or only FHD blurays?
This version played all my 5 samples.
Only Full HD menu works. Donât know why UHD doesnât. Iâm not even sure if they have been working in the past? Can someone tell me that?
