19.4 rc3
@vpeter thank you very much!
Thank You! ![]()
@vpeter will you do a 19.4 build pls?
CoreELEC-Amlogic-ng.arm-19.4-Matrix_vpeter-bdj-2022.03.07.20.07.tar
thank u very much! ![]()
Error Contents: /usr/lib/python3.8/site-packages/PIL/_imaging.so: undefined symbol: XauGetBestAuthByAddr
Any details to fix this?
I tried to build my own CoreELEC from source, and I got the same problem.
I think it comes from libX11 package?
Anyone tested UkkosJourney-BluPlay.iso with the latest version? It worked with older versions but seems not working any more.
It plays here as before.
OK, thanks. then this must be problem at my side. I will check more.
@vpeter Seems BD+ encrypted blu-rays doesnt work. Is that limitation of libbluray?
And if so is it possible that to be overcome somehow?
No idea - don’t have any to test ![]()
Do you have keys installed (KEYDB.cfg)? From here probably: http://fvonline-db.bplaced.net/
Yes i have keys installed. And i verify the key is there. However when i try to play BD+ blu-ray in kodi log this is the result:
2022-03-29 17:47:37.881 T:8288 ERROR : CDVDInputStreamBluray::Open - Media stream scrambled/encrypted with BD+
2022-03-29 17:47:37.881 T:8288 ERROR : CVideoPlayer::OpenInputStream - error opening [/var/media/EMPIRE_STRIKES_BACK/BDMV/index.bdmv]
I have abou 15 blurays that gives the same error and for all of them there are valid keys in keydb.cfg.
And if you play disk without menu: does it play?
Without menu doesnt play as well. Same error in the log. ![]()
I think is needed libbdplus which seems to be not included in kodi ![]()
It is: CoreELEC/package.mk at coreelec-19 · CoreELEC/CoreELEC · GitHub
$ fgrep -r libbdplus /usr/lib
Binary file /usr/lib/kodi/kodi.bin matches
Binary file /usr/lib/libbdplus.so.0.1.0 matches
Binary file /usr/lib/libbluray.so.2.4.0 matches
You could enable debug mode. Create file /run/libreelec/debug/kodi.conf with this content
AACS_DEBUG_FILE=/storage/debug_aacs
BD_DEBUG_FILE=/storage/debug_bd
AACS_DEBUG_MASK=0xffff
BD_DEBUG_MASK=0xffff
and then restart Kodi in ssh session (or from GUI) - restart and NOT reboot. You will get this two files in /storage.
systemctl restart kodi
@vpeter
I did what you told me…
When running fgrep -r libbdplus /usr/lib i get this output
/usr/lib/libbluray.so.2:Loading libbdplus (%p)
/usr/lib/libbluray.so.2:libbdplus dlsym failed! (%p)
/usr/lib/libbluray.so.2:Loaded libbdplus (%p)
/usr/lib/libbluray.so.2:libbdplus dlsym(bdplus_init) failed! (%p)
/usr/lib/libbluray.so.2:Too old libbdplus detected. Disc must be mounted first.
When i attempt to play the bluray disk AACS seems to be initilized correctly but bd+ seems to fail. Here is bd+ log:
bdplus.c:121: [bdplus] initialising...
bdplus.c:124: Initializing libgcrypt...
configfile.c:104: VM config not found from /storage/.config/bdplus/vm0/memory.map
configfile.c:104: VM config not found from /etc/xdg/bdplus/vm0/memory.map
bdplus_config.c:255: VM configuration not found
bdplus.c:240: bdplus_init() failed! (0xd7171f08)
dec.c:223: bdplus_init() failed
bdj.c:444: Using JAVA_HOME '/usr/share/kodi/addons/tools.jre.zulu'
bdj.c:309: Opening /usr/share/kodi/addons/tools.jre.zulu/jre/lib/arm/server/libjvm ...
dl_posix.c:56: opened library '/usr/share/kodi/addons/tools.jre.zulu/jre/lib/arm/server/libjvm.so'
file_posix.c:179: Opened POSIX file /usr/share/kodi/addons/tools.jre.zulu/libbluray-j2se-1.3.0.jar (0xd7170910)
file_posix.c:55: Closed POSIX file (0xd7170910)
file_posix.c:179: Opened POSIX file /usr/share/kodi/addons/tools.jre.zulu/libbluray-awt-j2se-1.3.0.jar (0xd7170910)
bdj.c:788: BD-J check: OK
bluray.c:3167: PSR change: psr3 = 1
bluray.c:3167: PSR change: psr4 = 65535
bluray.c:3167: PSR change: psr0 = 1
bluray.c:3167: PSR change: psr1 = 255
bluray.c:3167: PSR change: psr2 = 268374015
bluray.c:3167: PSR change: psr14 = 65535
bluray.c:1604: BLURAY destroyed!
Looks like bdplus is not initialized?
