I don’t know how to fix this. I assume it also doesn’t work on Windows?
I’ll try and check it out later.
I know that a few months back you tried da-andas patch for this problem instead of fandangos and it wasn’t working for me. Maybe it would play better with this new libbluray version?
You can try this image which has original patch from da-anda (and what is in Kodi 19) instead of patch from fandangos.
da-anda: allow chapter seeking in overlay menus of blu-rays
Sadly, it’s no good. With fandangos patch I have a 1/5 success rate with seeking in Java menus. With da-anda’s patch it’s 0/5.
I’ll check out how it works on Windows in the coming days.
thanks @vpeter its working great for my blurays.
I also tried this image and have no problems at all with it. Thank you!
It seems for me that Universal* BD ISOs work a lot better now. I still have problems with most Disney and Fox titles though. Maybe I’ll try to re-rip them…
Anyways! Thanks for this release it’s much appreciated! ![]()
EDIT
I wrote Panasonic at first but I meant Universal
So I tested two Kodi 19 versions for Windows with fandangos patch applied and I get the exact same behavior with remote buttons in Java menus. The ones that work well on CE work well on Windows too. The ones that don’t, don’t.
In this case maybe you should open some issue at Kodi?
Hi @vpeter will you do a 19.3 build if you have some time?
CoreELEC-Amlogic-ng.arm-19.3-Matrix_vpeter-bdj-2021.10.26.09.09.tar
Thanks vpeter!
Thank you very much!
whether this coreelec can support the BD-J menus?
How can I install your coreelec?
Why do you think it has bd-j in the name?
You install my version with updating official installation.
thank you 。I have solved.my device is ugoosX3,I install the CoreELEC-Amlogic-ng.arm-19.2-Matrix_vpeter-bdj-2021.10.10.13.07-da-anda to my coreelec.
Why not 19.3 version which is the last?
oh,I didn’t see it just now。Now I have installed 19.3
@vpeter will you do a matrix 19.4 build?
Untested.
Thnx for this
