Khadas VIM4 A311D2
Hello everyone, VIM4 now works perfectly under CE / Kodi 21. After 1 year, HD sound (Dolby Atmos, DTS-HD, DTS-X, etc.) works. Between the compactness, the graphics performance, and the ergonomics offered by Oowow, we have here a superb low-consumption multimedia box. We are therefore just a few steps away from the perfect UHD multimedia box. And we owe it to you, Team CE and its community. So for that, congratulations and thank you very much to everyone.
Is the implication of this being linked here that Amlogic-no/ce-21 includes the audio fixes?
Yes it is . Nightly release
Where are the settings for controlling fan of VIM4? In the NE build’s there was such a setting in the CoreELEC Configuration Addon. Now in the latest nightly NO build i can’t see it. It will be better if a user can specify at which temperature the fan will activate (not hardcoded 50 degrees only).
Hi, is anyone using this device as a media player with coreeles?
any major issues?
What remore control do you use?
Which case do you use if you have an active cooling?
Thanks for your help in advance
Actually there is only one small problem left on the stereo audios, on which the sound generates a crackle. But Khadas seems to be working on it. Otherwise, everything else works perfectly.
Hi, people, it is time to change my failing hp chromium box and I did some research and found out about coreelec ( was using libreelec) and Khadas VIM4.
But it seems that there is not a lot of love for this one.
Why is this?
There’s no problems I’m aware of running CE-NO on the VIM4. The VIM4 isn’t Dolby Vision certified, that and the price are I think the major reasons that this board doesn’t get more love.
The A311D2 competes with the S928X, and there are a number of cheaper DV-licensed S928X devices.
A311D2 - 4xA73 + 4xA53 cores
S928X - 1xA76 + 4x A55 cores
CE has also been overtaken by users that can’t live in a world without DV FEL playback, which is only supported on older CE-NG by older SOCs like the S922X (and S905X4). So the Ugoos AM6+ is a favorite.
S922X - 4xA73 + 2xA53 cores
Thank you,
Why DV FEL is important? and for which cases this is important?
ItĀ“s the ā€œHoly grailā€
Many users cannot live without FEL
Vim4 keeps rebooting on every 22 NO alpha..
Seems like reboots when accessing to emmc..
Each time - fresh install
The main problem is that after HBR audio passthrough was fixed, LPCM now exhibits constant clicking/popping, very evident when trying to play music.
IĀ“m currently thinking of getting a Vim4… So this LPCM problem is still an issue?
Still an issue, also no DV if you care about that. Would probably get a different device if I was going to purchase something new.
Hi, is there a CE-NO image available on the Oowow service for Vim 4?
Well, that message came a bit late! :smiley:
I already bought a VIM4 and could not make out the LPCM issue.
When does it occur on your side?
What I noticed is that the VIM4 has problems with 8K24pHDR AV1 files… Playback starts and then gets stuck…
Update on the VIM4 and PCM issue…
I can now also reproduce it, and it’s easily hearable…
Very weird that the VIM3 with almost the same bifrost gpu (G52 MP6 vs MP8 on the VIM4) does not exhibit the same issue…
It’s related to the amlogic kernel for the updated SoC - initially it would simply refuse to play high bitrate anything, then in the kernel version that fixed this, it introduced this LPCM issue.
