I see, is there any info I can send to you to help about?
I was testing it under Ubuntu and it is fully supported
I’m now using my new Vim4 and coreelec 20.1 as daily driver and I regret nothing. I have frame drops on heavier youtube 4k hdr 60fps, but the results are really good. If you need something tested, hit me up.
Vim 4 pretty solid if you don’t need pass through
I have it activated. Should I not?
EDIT: Disabling it seems to have fixed some audio sync mishaps on youtube.
I wouldn’t enable it since it doesn’t work
It works fine for sample rates <= 48Khz but high sample rate formates like DTS-MA/TrueHD do not work at all due to a broken audio driver, so you can enable it as long as you disable those formats.
Vim4 Coreelec 20-ne stable, nightly - dont see 1080p100hz display mode on Samsung The Frame 75". But recognize and work at 1080p120hz.
Coreelec 21-ne nightly sees both 1080p100hz and 1080p120hz, but doesnt work at niether of those (corrupted display).
However both have the record “1920x1080p100hz” (not “1080p100hz”) in /sys/class/amhdmitx/amhdmitx0/disp_cap.
Have to mention that old Libreelec tv-box succesfully recognizes and works at both modes, so its not a TV/cable issue.
Tried to use disp_cap to override EDID - Coreelec just ignores any data in disp_cap. I can edit it to “480p30hz” - nothing happens - just the same resolution list.
I guess something has changed in the latter releases/or there’s something special for this exact hardware/or just a bug.
So whats the current way of overriding EDID?
disp_cap have no function in 5.4 kernel. Our team have no such TVs so we can’t test it at all.
EDID can not be overwritten.
Dont you have ANY 100hz TVs?
No, and also only 50/60hz videos.
We blew all the money earned with CoreELEC in a mansion for each member. We forgot about the 100hz tv.
All tĥat has to be on the homepage as “features” ;))
FWIW, on my Sony 1080p 120Hz works fine, suspect your EDID is busted.
EDIT: Oh, I see 120Hz works fine for patkino too, post is confusingly formatted.
There is now a audio test image for VIM4 Amlogic T7 available:
It might fix HBR Audio TrueHD and DTS-MA passthrough.
Please have a test!
A clean fresh install is preferred over an update!
Will oowow image be made available?
It’s handled by Khadas, not us.
I don’t think NO is ready right now for OOWOW.
Copied the contents from /flash from usb to emmc and it works. Running great Thanks
Well this change be available for the Beelink GT King II? It is also a A311D2 box although the CE wiki might need to be updated.
