If you didn’t see an error message, everything should be fine. Just reboot your box and try to use your remote afterwards.
I’ve just done it so but the remote still doesn’t work.
Remove your “remote.conf” in this folder and reboot again.
Thank you so much. The remote is working finally. I should have deleted the previous file before writing the command on SSH.
Hi
I tried “meson-ir” command, but it doesn’t exist in my updated CoreElec version (KIII Pro). Was it removed from standard installation?
Thank you
