Kinhank G1
@Zuma Do you think you can download BL_EL.mkv from the link below and see if the woman appears? I think many people are curious if the S905X4-J in the G1 can support Dolby Vision FEL and that video will test it out: woman appears means that it can support FEL. Before you do the test, can you make sure that Dolby Vision output is set to Lossless.
i try in android & coreelec
i cant see woman appears
only color…
i think dtb.img for G1 not support DV
so no option for DV in setting
here last dmesg for rc2
CoreELEC (official): 21.0-Omega_rc2 (Amlogic-ne.aarch64)
      Machine model: Amlogic
     CoreELEC dt-id: sc2_s905x4_4g
CoreELEC:~ # dmesg | grep wifi
[    0.672557@0]  aml_wifi aml_wifi: [wifi_dev_probe] use double channel
[    5.987003@0]  wifi_dummy: loading out-of-tree module taints kernel.
[    5.987370@0]  aml_wifi aml_wifi: [extern_wifi_set_enable] WIFI  Disable! 481
[    6.302257@3]  aml_wifi aml_wifi: [extern_wifi_set_enable] WIFI  Enable! 481
CoreELEC:~ # dmesg | grep eth
[    0.890010@3]  meson8b-dwmac fdc00000.ethernet: IRQ eth_wake_irq not found
[    0.890018@3]  meson8b-dwmac fdc00000.ethernet: IRQ eth_lpi not found
[    0.890100@3]  meson8b-dwmac fdc00000.ethernet: PTP uses main clock
[    0.890108@3]  meson8b-dwmac fdc00000.ethernet: no reset control found
[    0.890582@3]  meson8b-dwmac fdc00000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[    0.890593@3]  meson8b-dwmac fdc00000.ethernet:   DWMAC1000
[    0.890599@3]  meson8b-dwmac fdc00000.ethernet: DMA HW capability register supported
[    0.890604@3]  meson8b-dwmac fdc00000.ethernet: RX Checksum Offload Engine supported
[    0.890609@3]  meson8b-dwmac fdc00000.ethernet: COE Type 2
[    0.890614@3]  meson8b-dwmac fdc00000.ethernet: TX Checksum insertion supported
[    0.890619@3]  meson8b-dwmac fdc00000.ethernet: Wake-Up On Lan supported
[    0.890654@3]  meson8b-dwmac fdc00000.ethernet: Normal descriptors
[    0.890659@3]  meson8b-dwmac fdc00000.ethernet: Ring mode enabled
[    0.890664@3]  meson8b-dwmac fdc00000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    0.891288@3]  meson8b-dwmac fdc00000.ethernet: Unable to get resource(385)
[    2.335373@2]  VAD fe330000.audiobus:vad: check whether to update vad chipinfo
[   11.691045@3]  meson8b-dwmac fdc00000.ethernet eth0: PHY [0.1:08] driver [Meson G12A Internal PHY]
[   11.702260@3]  meson8b-dwmac fdc00000.ethernet eth0: No Safety Features support found
[   11.702307@3]  meson8b-dwmac fdc00000.ethernet eth0: PTP not supported by HW
[   11.702326@3]  meson8b-dwmac fdc00000.ethernet eth0: configuring for phy/rmii link mode
Android does not support FEL above kernel 4.9.
Is there a download link to the Android firmware?
The hardware seems to be nice for media playback. So this BOX is not optimal for NO?
Thank you for testing!
there is no firmware available,
but i can access system android from coreelec
The device is very cheap, and has a license to run Dolby Vision, but the Ethernet speed is 100Mbps and we have not found a driver for it, yet.
Then please share your Android dovi.ko maybe located in
/android/oem/overlay/dovi.ko
/android/odm/lib/modules/dovi.ko
dovi.ko (1.5 MB)
vendor-etc-wifi.rar (10.0 MB)
kernel 5.4.210 in android 11
@Portisch Can Coreelec theoretically decode FEL with kernel above 4.9?
Did a quick test on my Homatics. The dovi.ko works on the Homatics in MEL, but gives a black screen in Lossless mode.
It should work, yes. This is the reason we think it’s the suffix J give FEL support.
Is this statement subtly different from the previous one
Amlogic uses a suffix of J or K in their SoC model names to denote if the SoC is licensed for Dolby Vision
in that now it is believed the -J indicates FEL. Does this imply that other parts of dolby vision are possible without the -J?
I want to buy this device, any news about the network and dolby vision?
I have this device now on the table but not started yet debugging.
It did boot CE and Dolby Vision does work like on Homatics, no P7 FEL support.
Awesome
What was the version CoreELEC and dtb you used and the speed of your Wi-Fi network?
I bought now
Thank you
Hmmmmmm
Interesting box
Just watched u tube video review
From image posted
So ap 6275pr3 is wifi/ bluetooth combo
Wifi 6 and bluetooth 5.0 ?
What is this MXL
Max linear ethernet transceiver?
I maybe think so to, it’s market with SLLHU C1050.04 2112 K.
I get the chip listed now but there is only TX, no RX
[ 40.265257@2] meson8b-dwmac fdc00000.ethernet eth0: PHY [0.0:06, 0xd565a401] driver [Intel XWAY PHY11G (PEF 7071/PEF 7072) v1.5 / v1.6]
eth0      Link encap:Ethernet  HWaddr 5C:7B:5C:BC:45:CD
          inet addr:169.254.205.4  Bcast:169.254.255.255  Mask:255.255.0.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:63 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:19698 (19.2 KiB)
          Interrupt:41
The vendor can be contacted and asked about the changes he did in 5.4.210 kernel to get it work?
any build this?
i can try again
