Zuma
1
Hi
i have this box:
https://www.amazon.com/Kinhank-Android-TV-Box-G1/dp/B0CQLJ6TZM?th=1
and boot via “sc2_s905x4_4g.dtb” and remote work if i use remote.conf for Dune Homatics, DV not test
but no wifi or Ethernet work
any help
UPDATE:
THANKS FOR COREELEC TEAM, NOW G1 FULL SUPPORT
for remote.conf copy file to flash sd card , here file:
https://discourse.coreelec.org/uploads/short-url/hyFXRsr9BZkxG1Twx53653XX5Jz.conf
for fix “ENTER” if use BT remote G1 :
https://wiki.coreelec.org/coreelec:devicetree
Zuma
3
i try boot via sdcard and use usb wifi for ssh
Connecting to 192.168.100.xx port 22, please wait...
login as: root root@192.168.100.xx's password:
# CoreELEC #
# https://coreelec.org #
CoreELEC (official): 20.4-Nexus (Amlogic-ne.aarch64)
Machine model: Amlogic
CoreELEC dt-id: sc2_s905x4_4g
CoreELEC:~ # dd if=/dev/dtb | gzip > /storage/backup/dtb.img.gz
512+0 records in
512+0 records out
262144 bytes (256.0KB) copied, 0.059329 seconds, 4.2MB/s
CoreELEC:~ # udevadm info /sys/bus/sdio/devices/* | paste
Unknown device "/sys/bus/sdio/devices/*": No such device
https://paste.coreelec.org/ZyWtji
CoreELEC:~ # lsusb | paste
https://paste.coreelec.org/N8XCYe
CoreELEC:~ # udevadm info /sys/bus/pci/devices/* | paste
Unknown device "/sys/bus/pci/devices/*": No such device
https://paste.coreelec.org/jRVIxb
CoreELEC:~ # lspci | paste
https://paste.coreelec.org/aNW01j
CoreELEC:~ # dmesg | paste
https://paste.coreelec.org/7rsW2l
dtb.img.gz (84.5 KB)
Zuma
4
@Portisch
Is there anything I can do to reach support to resolve the issue?
Can opening the box of the device and knowing its components help us?
It will require only a bit more time to find a free slot to take a look…
Please try to boot Amlogic-no and make same logs again please: Kinhank G1 - #3 by Zuma
Test if LAN or Wifi is already working.
dtb.img.gz is not need anymore, thx.
Zuma
7
still issue
CoreELEC
CoreELEC (official): 21.0-Omega_nightly_20240308 (Amlogic-no.aarch64)
Unknown device “/sys/bus/sdio/devices/*”: No such device
https://paste.coreelec.org/AYyuY4
https://paste.coreelec.org/bwOHrC
Unknown device “/sys/bus/pci/devices/*”: No such device
https://paste.coreelec.org/6EkOgi
https://paste.coreelec.org/DlE572
https://paste.coreelec.org/EE9fRY
CoreELEC:~ #
Under Android you have LAN and Wifi?
Wifi are normally connected by SDIO but it only receive a timeout. It can also be a power gpio we don’t know.
Zuma
9
here logcat android
logcat.txt (764.8 KB)
This logcat does not include dmesg, only Android stuff.
Zuma
11
So maybe really some unknown gpio is used to power the chip.
What about eth0, LAN? Is there a chip mounted at all?
Zuma
14
you mean eth in coreelec system ?
no, on PCB. Your photo only shows the Wifi chip.
You have another gigabit chip assembled.
Android dmesg is required and maybe a driver as well…
Zuma
18
is any way for dmesg without root ?
i try “logcat -b kernel” but nothing
i can get info via
adb shell logcat -v time
adb shell logcat -v time adb shell cat /proc/kmsg
adb shell logcat -v time adb shell cat /dev/kmsg
Zuma
19
adb shell logcat -v time > C:\adb\logcat-v-time.txt
adb shell logcat -v time adb shell cat /proc/kmsg > C:\adb\kmsgproce.txt
adb shell logcat -v time adb shell cat /dev/kmsg > C:\adb\kmsgdev.txt
adb shell logcat -v time adb shell cat dmesg > C:\adb\dmesg.txt
i think wifi is: NL80211
dmesg1.txt (2.3 MB)
dmesg2.txt (2.2 MB)
kmsgdev.txt (2.2 MB)
kmsgproce.txt (2.2 MB)
logcat-v-time.txt (2.0 MB)
Zuma
20
any news for add driver : NL80211 ?
