Kinhank G1
Because you don’t follow our rules. We did mention multiple times you should not post any logs anymore and put instead your device online with tmate.
But nothing happen so we are forced to clean up the posts with logs you do.
for me i try :CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20240413-Generic.img
and no issue for wifi & eth
May I ask if your wifi and bluetooth are ap6275p with pcie interface?
WIFI6: AP6275 PR3
My model is AP6275P, and the interface is PCIE, which is different from yours.
@blueyeti2000 this is the last time info for you: put your device online with tmate and keep in online. Or stop posting and asking for help and support.
Hello sorry for my English I use translator thank you for all the work I have a kinhank g1 with coreelec ne and dtb of kinhank g1 everything works very well for me but hdr10+ doesn’t work for me the other hdr if they work my TV is compatible can it be solved in any way?
Zuma
Have you tested Dolby Vision yet?
Profile 5 i guess??
There is no profile 7 FEL
I have one of these boxes on the way!!!
Looking forward to Testing
Have been following Dolby Vision Threads
For months
So had to get in game
all my Movie DV working fine
but i think same homatic not support p7
Thanks for feedback.
Box came yesterday!!!
Just ran dmesg | grep ’ dv capability ’
Came back as
dv capability 7
So iam more confused now
After reading so much about last 6 months
More reading/research to be done
If you want dv p7 without conversion, you will need the AM6B+ or Minix U22XJ.
The best way to test FEL support is to download BL_EL.mkv from 1.58 GB folder on MEGA and see if the woman appears. Make sure to set Dolby Vision output to lossless in Player → Video.
No info:
#dmesg | grep ’ dv capability ’
grep: dv: No such file or directory
grep: capability: No such file or directory
but i have info dv here:
dmesg | grep dolby_vision
[    1.208025@2]  amdolby_vision_init:module init
[    1.208315@2]   amdolby_vision probe start & ver: 2023000423
[    1.209177@2]  amdolby_vision_probe: ok
[    1.209342@2]  call amdolby_vision_init() ret=0
[   17.513597@0]  *** amlogic_dolby_vision_init dv: sc2 ***
Iam typing on mobile phone so keyboard layout is bit different
Looks like you have slash instead of pipe | after dmesg
Also no space after uppercase dv capability
So dmesg | grep dv capability
Iam not sure if iam described this character correctly
I get same result as you with
Another question?
Do you have Bluetooth Working
i try it without ’ same:
BT not working yet
i think remote working via IR same Dune Homatics
BT is working since new nightly 20240417.
Hdr10+ will it be able to support it or is it impossible due to compatibility?
It is not important anyway
Its just something i remember when researching Dolby Vision.
Its a quick check to see if SoC supports DV
A 1,3,5,7 indicates does support
So the 7 has nothing to do with Profile 7
