Since my return from two week holidays LibreSpot is not working. Kodi is visible through the Spotify app on android, but when I try to push music to it it’s trying to connect, but it always fails.Yesterday I have even tried to return to default settings for CoreELEC and install only LibreSpot addon (using version 20.2.2 by Anton Voyl from CoreELEC repository) and the effect is the same.
I would like to mention, that there was an CoreELEC update when I started my box after my return (Saturday evening), and I have updated it at once. Unfortunately I haven’t checked the if it was working before the update, but maybe it is related?
In the logs I cannot find anything suspicious but here is the log:
Has anyone expierience similar problem? This addon is crucial for me.
Best regards
Cube
Is there a other user that is using succesfully the LibreSpot on his CoreELEC?
If there is someonte, that would like to test I can give him one of my Family profile for testing.
I tried all available CE-20 versions and also the final CE-19. Also tried disabling avahi and run it with arguments “–disable-discovery --username x --password x” as suggested by someone in another thread. Can’t get it to work unfortunately.
well it doesnt connect, like the other people here say, same problem. Mobile android app shows “connecting”, but nothing happens. Started with the CoreElec Update. Every other device in the network (AVR, Volumio an Raspberry) work perfectly, so it is not a problem of anything but Corelec’s librespot
