Sorry, I can’t compile. I must be missing something. I installed the toolchains and everything but no go.
What machine/cpu did you use to compile? Did you crosscompile or using the native box?
CoreELEC 9.2.2, Odroid C4 with a TP-LINK Archer T2U not working (it worked with the same configuration on Odroid C2), this is the verbose log (cut to the dongle part), thank you
Bus 001 Device 003: ID 148f:761a Ralink Technology, Corp. MT7610U ("Archer T2U" 2.4G+5G WLAN Adapter
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.01
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x148f Ralink Technology, Corp.
idProduct 0x761a MT7610U ("Archer T2U" 2.4G+5G WLAN Adapter
bcdDevice 1.00
iManufacturer 1 MediaTek
iProduct 2 WiFi
iSerial 3 1.0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 74
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 160mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 8
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 2
bInterfaceProtocol 255
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x08 EP 8 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x07 EP 7 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x09 EP 9 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 12
bNumDeviceCaps 1
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
HIRD Link Power Management (LPM) Supported
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0000
(Bus Powered)
How is it not working? Is it not showing wifi networks? Not connecting to a network? not staying connected to a network?
Is your wifi 2.4ghz or 5ghz?
Can you post the output of
lsmod
I found this that compiles on my ARM ubuntu, but don’t know how to proper cross compile it for CoreELEC ARM.
mt7668-bt-drv.tar.gz (124.3 KB)
sorry for the lack of information.
The dongle is not recognized inside Kodi, I cannot see the wifi configuration and network selection (it seems like there’s no dongle connected), the little light on the dongle is off.
At home I have both 2.4GHz and 5GHz networks.
Tonight I’ll post the output of lsmod.
Yesterday I tested the Odroid C2: it connects to the 2.4GHz network, I can see the 5GHz network but cannot connect to it.
I also noticed the 2.4GHz network is very slow (it buffers a lot on a 2Gb video file) even if the wifi signal is strong, making it pretty unusable. I do not have wifi problems on the other devices (smartphone, tablet, laptop).
Let me know if you need further information
Thank you
Here’s the output
Module Size Used by
8021q 36864 0
mali_kbase 499712 3
ir_lirc_codec 16384 0
lirc_dev 24576 1 ir_lirc_codec
meson_ir 16384 0
rc_core 36864 4 ir_lirc_codec,meson_ir,lirc_dev
wireguard 143360 0
ip6_udp_tunnel 16384 1 wireguard
wifi_dummy 16384 0
vpu 53248 0
encoder 57344 0
amvdec_vp9 126976 0
amvdec_vc1 65536 0
amvdec_real 45056 0
amvdec_ports 200704 0
v4l2_common 16384 1 amvdec_ports
videobuf2_dma_contig 20480 1 amvdec_ports
videobuf2_memops 16384 1 videobuf2_dma_contig
v4l2_mem2mem 28672 1 amvdec_ports
videobuf2_v4l2 28672 2 amvdec_ports,v4l2_mem2mem
videobuf2_core 49152 3 amvdec_ports,v4l2_mem2mem,videobuf2_v4l2
amvdec_mpeg4 65536 0
amvdec_mpeg12 106496 0
amvdec_mmpeg4 40960 0
amvdec_mmpeg12 45056 0
amvdec_mmjpeg 32768 0
amvdec_mjpeg 40960 0
amvdec_mh264 163840 0
amvdec_h265 155648 0
amvdec_h264mvc 61440 0
amvdec_h264 147456 0
amvdec_avs 69632 0
amvdec_avs2 212992 0
stream_input 192512 11 amvdec_h265,amvdec_mh264,amvdec_h264mvc,amvdec_ports,amvdec_real,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_mmpeg12
decoder_common 184320 18 amvdec_h265,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_mmjpeg,amvdec_ports,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,encoder,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mmpeg12,amvdec_mpeg4
firmware 28672 18 amvdec_h265,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_mmjpeg,decoder_common,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,encoder,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mmpeg12,amvdec_mpeg4
media_clock 45056 13 amvdec_h265,amvdec_mh264,decoder_common,vpu,amvdec_ports,firmware,stream_input,amvdec_vp9,amvdec_h264,encoder,amvdec_avs2,amvdec_mpeg12,amvdec_avs
amlvideodri 24576 0
videobuf_res 16384 1 amlvideodri
videobuf_core 32768 2 amlvideodri,videobuf_res
videodev 286720 6 amlvideodri,v4l2_common,amvdec_ports,videobuf2_core,v4l2_mem2mem,videobuf2_v4l2
media 40960 1 videodev
quota_v2 16384 0
quota_tree 20480 1 quota_v2
fbcon 61440 0
bitblit 16384 1 fbcon
softcursor 16384 1 bitblit
font 20480 1 fbcon
Vontar x96 [s905x] 2/16
CoreELEC (official): nightly_20200523 (Amlogic.arm)
RTL8723BS
BT not working
WiFi OK
P: /devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH=/devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: DRIVER=rtl8723bs
E: SDIO_CLASS=07
E: SDIO_ID=024C:B723
E: MODALIAS=sdio:c07v024CdB723
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=10410745
E: SYSTEMD_WANTS=rtl8723bs_bt-firmware.service
E: TAGS=:systemd:
dmesg|paste
http://ix.io/2nk7
RTL8723BS
I tried a bunch of versions
But on these BT module does not see
CoreELEC-Amlogic.arm-9.2-nightly_20200220.tar
CoreELEC-Amlogic.arm-9.2-nightly_20200316.tar
CoreELEC-Amlogic.arm-9.2-nightly_20200413.tar
CoreELEC-Amlogic.arm-9.2-nightly_20200415.tar
CoreELEC-Amlogic.arm-9.2-nightly_20200423.tar
CoreELEC-Amlogic.arm-9.2.0-Generic.img.gz
Here on these sees the module, but does not connect
CoreELEC-Amlogic.arm-9.2-nightly_20200523.tar
CoreELEC-Amlogic.arm-9.2-nightly_20200525.tar
And here it works and connects
CoreELEC-Amlogic-ng.arm-9.2-funhouse_2011.6-Generic.img.gz
Hi cdu13a, is the information provided enough? Do you need other info?
Thank you
Bluetooth Dongle not working
Odroid N2
1Mii B10 Bluetooth Dongle
CoreELEC (nightly) 20200528
lsusb
Bus 001 Device 003: ID 0a12:1004 Cambridge Silicon Radiio, Ltd
Please reboot and run the following commands:
dmesg | paste
lsusb -v | paste
Then post the URLs these commands return.
A post was merged into an existing topic: Odroid N2 - WiFi Issues, General Setup Questions
ciao Guys,
My S905X3 box’s built-in bluetooth is not working. The driver starts, hci0 comes up but the audio output is lagging.
HCI Version: 4.2 (0x8) Revision: 0xaa89
LMP Version: 4.2 (0x8) Subversion: 0x7e1c
Manufacturer: Realtek Semiconductor Corporation (93)
I can use the box with a dongle (the audio is perfect) but if I blacklist the bt-uart module somehow rfkill blocks bluetooth on boot and I must log in and unblock it manually (despite bt-usb is loaded). The block runs in the very end of the booting process after autroun.sh can execute ‘rfkill unblock bluetooth’.
According to the dmesg, and also this thread, what you got is not a bluetooth adapter.
It’s also possible that linux doesn’t see it as an actual bt adapter. In any case it seems that it’s not supported.
is there something else I should do in order to give you details on my issue?
Guys, can anybody tell me how can I prevent rfkill blocks bluetooth? I really did not find any trace of it
thanks!
MeCool M8S Pro Plus
No WiFi, No Bluetooth
CoreELEC (official): 9.2.2
L: 0
E: SDIO_CLASS=07
E: SDIO_ID=02E7:9082
E: MODALIAS=sdio:c07v02E7d9082
E: SUBSYSTEM=sdio
Please try latest nightly first to make sure a problem still exists.
9082xs wifi is not supported.
@anon88919003 Hi, still no news regarding the BT for MT7668 ?
I found that there is a Linux version (Yocto Linux) supporting a board called # Pumpkin Evaluation Kit Smart Audio Edition that has the same MT7668 chip.
I tried to check, but my Linux source knowledge is limited so I didn’t know where to look so far.
