Thanks for the feedback and testing @wkchick.
Vorke Z6 (S912)
P: /devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH=/devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: DRIVER=ar6k_wlan
E: SDIO_CLASS=00
E: SDIO_ID=0271:0701
E: MODALIAS=sdio:c00v0271d0701
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=8100573
E: SYSTEMD_WANTS=qca9377-firmware-aml.service
E: TAGS=:systemd:
thanks in advance
I update to laetst image (nightly_20200220) and I have no wifi nor bt.
My device is X96Max. Here is the info: http://ix.io/25ha
If you need more info, just ask for it.
Thanks for your great work.
Regards.
@jlazkano you have RTL8189FTV, this chip has no BT.
https://www.realtek.com/en/products/communications-network-ics/item/rtl8189ftv
I will look into adding support for this chip into our -ng builds as the driver already exists for older devices.
Thanks for support this device.
@undef WiFi should work for you in tonights build as @grimgriefer has successfully tested it, I’m still working on BT.
no wifi no BT… just eth works.
Transpeed A95X F3 4/32GB
P: /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH=/devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: SDIO_CLASS=00
E: SDIO_ID=037A:7608
E: MODALIAS=sdio:c00v037Ad7608
E: SUBSYSTEM=sdio
P: /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:2
L: 0
E: DEVPATH=/devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:2
E: SDIO_CLASS=00
E: SDIO_ID=037A:7668
E: MODALIAS=sdio:c00v037Ad7668
E: SUBSYSTEM=sdio
@kodiwpigulce_pl yours is the same chipset as @undef and @grimgriefer, refer to my above post.
Magicsee N5 MAX s905x3 4GB RAM
Not working BT, Wifi OK.
L: 0
E: DRIVER=rtl88x2bs
E: SDIO_CLASS=07
E: SDIO_ID=024C:B822
E: MODALIAS=sdio:c07v024CdB822
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=7725135
E: SYSTEMD_WANTS=rtkbt-firmware-aml.service
E: TAGS=:systemd:
X96S 2GB is good with the latest drivers.
WIFI is now working but still no BT.
Thanks!
@kodiwpigulce_pl I did say to refer to my previous post where I said that I was still working on BT.
T95N TV box:
L: 0
E: SDIO_CLASS=07
E: SDIO_ID=02E7:9082
E: MODALIAS=sdio:c07v02E7d9082
E: SUBSYSTEM=sdio
@hav you have the 9082xs the same as the Tanix TX3 Mini, this is one chip that we are unable to add support for unfortunately as there was no driver ever made available for it due to it being a cloned Realtek chip.
