Looking for users with no working WiFi or BT
I’m sorry I missed your request because I haven’t visited the forum for days. I just saw (maybe yesterday) that the Wi-Fi started working.
dmesg from the latest version: 20230113
http://ix.io/4l3x
Thanks for your help in solving the issue.
I can connect and pair some BT remotes to the Beelink GT King II but I can’t get them to function. They don’t show with cat /proc/bus/input/devices (but they do in Android)
Looking at the journal I do get this error
Jan 13 22:08:50 Beelink bluetoothd[792]: profiles/deviceinfo/deviceinfo.c:read_pnpid_cb() Error reading PNP_ID value: Request attribute has encountered an unlikely error
Jan 13 22:08:50 Beelink bluetoothd[792]: profiles/input/hog-lib.c:proto_mode_read_cb() Protocol Mode characteristic read failed: Request attribute has encountered an unlikely error
Jan 13 22:08:50 Beelink bluetoothd[792]: profiles/input/hog-lib.c:report_reference_cb() Read Report Reference descriptor failed: Request attribute has encountered an unlikely error
Jan 13 22:08:50 Beelink bluetoothd[792]: profiles/input/hog-lib.c:external_report_reference_cb() Read External Report Reference descriptor failed: Request attribute has encountered an unlikely error
Jan 13 22:08:50 Beelink bluetoothd[792]: profiles/input/hog-lib.c:info_read_cb() HID Information read failed: Request attribute has encountered an unlikely error
Jan 13 22:09:00 Beelink bluetoothd[792]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
Jan 13 22:09:02 Beelink kernel: hid-generic 0005:0957:0005.0001: item fetching failed at offset 22/23
Jan 13 22:09:02 Beelink kernel: hid-generic: probe of 0005:0957:0005.0001 failed with error -22
I tried Ugoos A7 control in GT King II and worked
My original remote didn’t work at all, they sent a new one from China and it seems to only work in IR mode, since I can’t start it pairing, even in Android (not flashing red). I don’t like the stock remote anyway, which is why I like to see one of my preferred BT remotes working.
Hi, @Portisch Tanix w2 (s905w2): is it normal for Wi-Fi networks to appear duplicated? On the other hand, there is no Bluetooth interface, but in Android it was.
http://ix.io/4lMe
dmesg: http://ix.io/4lMd
Hello @Portisch , something about this?
no time for such non supported devices…
BT is still not working as the software is not trivial to setup
Oh, okay. Sorry, I thought s905w2 devices were supported on Coreelec NE.
hi community & dev team,
my problem is: Unisoc UWE5621DS wifi/bluetooth not work in 19.5 and 20.0
i have a box of UNT413A which has basically the same h/w specs with E900V22C, with a wifi/bluetooth of UNISOC UWE5621DS chip.
i saw its support from 19.5 Added Wifi driver Unisoc UWE5621.
i tried both CoreELEC-Amlogic-ng.arm-20.0-Nexus-Generic.img.gz and CoreELEC-Amlogic-ng.arm-19.5-Matrix-Generic.img.gz, but both failed to find the chip.
i used dmesg | grep uni/soc/5621/uwe (one for each command), and its output was empty (found nothing).
i used dmesg -c && cd /usr/lib/modules/4.9.269/uwe5631-aml/ && insmod ./sprdbt_tty.ko/sprdwl_ng.ko/uwe5621_bsp_sdio.ko. it still found nothing with ifconfig, no new network interface.
i tried https://github.com/KryptonLee/e900v22c-CoreELEC with the image CoreELEC-Amlogic-ng.arm-19.5-Matrix_rc3-E900V22C-2022.12.17.img.gz, and wifi/bluetooth worked.
but i’d like to use the official image so as to keep pace with the up2date features and fixes.
and, i used g12a_s905x2_2g.dtb → dtb.img for official images, and did not copy/rename the dtb file for KryptonLee’s build because his readme says the correct dtb.img is ready to use.
do hope someone can help to solve this problem.
many thanks!
S905w2 is supported in the NE.
Tanix and other junk Chinese boxes are not supported…
A great entry, welcome. Could you tell me which tvbox, with s905w2, would be compatible?
Instead of wasting time and money on a weak Chinese android box
I suggest you buy an officially supported device
You will find a list at the bottom of the page:
I have some issues with the WiFi:
I have wlan0 and p2p0 for the same access point.
Sometimes I loose the wlan0.
The Kodi 20-ne is installed
In my X96Max Plus (T version) with AP6330 I do not use wifi although it seems to work, but I would like to use bluoetooth to connect to headphones.
It turns out to be unusable, a few times I was able to pair up the headphones but after a few seconds the audio starts to go off.
Many times it is difficult to even make the pairing, and headphones with a regular Android smartphone works perfectly.
X96 Max Plus T
S905X3 4/64
CE v19.5 Matrix
dtb used : sm1_s905x3_4g_1gbit.dtb
http://ix.io/4nDy
http://ix.io/4nDz
Try again with clean CE-20, CE-19 is EOSD.
Tried now, same issue. :smiling_face_with_tear:
Your problem is buying cheap hardware without knowing anything about the inside of the device.
So your chip maybe need a newer firmware, nobody knows. When it’s working in Android maybe a dmesg log of Android will help. But don’t bet to much on this get solved…
2023-02-10 19:23:08.833 T:4006     info <general>: JSONRPC Server: New connection added
2023-02-10 19:23:28.831 T:3957     info <general>: CActiveAESink::OpenSink - initialize sink
2023-02-10 19:23:28.831 T:3957     info <general>: CAESinkALSA::Initialize - Attempting to open device "@"
2023-02-10 19:23:28.838 T:3957     info <general>: CAESinkALSA::Initialize - Opened device "sysdefault"
2023-02-10 19:23:28.838 T:3957     info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-02-10 19:23:28.838 T:3957     info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-02-10 19:23:34.313 T:4071     info <general>: ## CoreELEC Addon ## _service_::run ## MESSAGE:openConfigurationWindow
2023-02-10 19:23:34.338 T:3928     info <general>: Loading skin file: /usr/share/kodi/addons/service.coreelec.settings/resources/skins/skin.estuary/xml/service-CoreELEC-Settings-mainWindow.xml, load type: LOAD_ON_GUI_INIT
2023-02-10 19:23:34.372 T:3928    error <general>: Control 1000 in window 13000 has been asked to focus, but it can't
2023-02-10 19:23:34.395 T:4071     info <general>: ## CoreELEC Addon ## _service_::run ## WAITING:
2023-02-10 19:24:03.573 T:4070    error <general>: ## CoreELEC Addon ## bluetooth::dbus_error_handler ## ERROR: (br-connection-aborted-by-local)
2023-02-10 19:24:08.602 T:4070  warning <general>: SplitParams("Bluetooth error", "Method "Connect" with signature "" on interface "org", 5000, "/usr/share/kodi/addons/service.coreelec.settings//resources/skins/Default/media/bt.png") - end of string while searching for ) or "
2023-02-10 19:24:08.602 T:4070    error <general>: ## CoreELEC Addon ## bluetooth::dbus_error_handler ## ERROR: (Method "Connect" with signature "" on interface "org.bluez.Device1" doesn't exist
2023-02-10 19:24:08.614 T:3928  warning <general>: SplitParams("Bluetooth error", "Method "Connect" with signature "" on interface "org", 5000, "/usr/share/kodi/addons/service.coreelec.settings//resources/skins/Default/media/bt.png") - end of string while searching for ) or "
2023-02-10 19:24:40.371 T:4006     info <general>: JSONRPC Server: Disconnection detected
On being cheap for sure, but it works superbly on everything else with CoreELEC, only the bluetooth here gives poblems.
Cheap or not it is always a question of drivers and firmware, since just with Android the same headset works fine.
I will try a bluetooth usb adapter.
I have an X98mini box on Android, wifi and LAN work perfectly, on CE wifi does not work and LAN is very bad.
