It is recommended to brush the latest ne version every night edition.
CoreELEC:~ # mount -o rw,remount /flash
CoreELEC:~ # fdtput -t s /flash/dtb.img /soc/pcie@f5000000 status okay
CoreELEC:~ # sync
CoreELEC:~ # reboot
CoreELEC:~ # lspci | paste
CoreELEC:~ # udevadm info /sys/bus/pci/devices/* | paste
Run the preceding command to check whether the pcie link can be obtained.
If the log link is obtained, please post the link and wait for it to be adapted. @Tuxino
CoreELEC 21.0-Omega_alpha3 on Tvbox Tanix x4 s905x4.
Immediately after entering the WiFi password, the following
message is displayed: Error. Operation timeout.
After selecting the Access point checkbox, the interface is
automatically refreshed and the field is automatically deleted.
It’s been a month since this publication has not received a response. I would like you to tell me, if possible, if the fact that the wifi does not work is due to the unavailability of the driver or any other reason. I find it strange that bluetooth works and not wifi. I appreciate your effort and dedication, thank you for everything.
I did check now your messages and I found minimum 3 different Wifi chips in your log.
Do you use multiple different devices?
One time the pid 8888, one time the 4339 and one time the 4330 . No idea what you are doing.
Please make a new log and tell us exactly what log to wich device is related to: udevadm info /sys/bus/sdio/devices/* | paste
Also a Android dmesg log would be helpful to easy define the used WiFi driver.
Ok, there is something else missing. Please connect the device by ethernet and open tomorrow morning a tmate session: coreelec:term_share [CoreELEC Wiki]
Thanks for all the efforts to make wifi work in our device!
It’s been a while since your last message. Were you able to sort the issues with the H96 Max W2?
I don’t have the expertise to help you but would love to see our device running CoreELEC. Could you someone else give us a helping hand?
