No detecta adaptador bluetooth en coreelec 21ne Alpha 1 en tanix tx3 mini+ s905w2
no funciona bluethoo
tanix tx3 mini plus S905w2
http://ix.io/4JWW
http://ix.io/4JWY
http://ix.io/4JX0
http://ix.io/4JX2
pongo todos los link porque no se donde hay que mirarlo
Hey all,
WHat’s the status of 5BK support on CE 21? I’m running vanilla 21.0-Omega_nightly_20231108 and BT works out of the box, wifi doesn’t see any SSIDs
It’s working fine in MATE so hardware is good
Bus 001 Device 003: ID 0bda:c820 Realtek Semiconductor Corp. 802.11ac NIC
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 [unknown]
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x0bda Realtek Semiconductor Corp.
idProduct 0xc820 802.11ac NIC
bcdDevice 2.00
iManufacturer 1 Realtek
iProduct 2 802.11ac NIC
iSerial 3 123456
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x00e5
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 224 Wireless
bFunctionSubClass 1 Radio Frequency
bFunctionProtocol 1 Bluetooth
iFunction 4 Bluetooth Radio
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 224 Wireless
bInterfaceSubClass 1 Radio Frequency
bInterfaceProtocol 1 Bluetooth
iInterface 4 Bluetooth Radio
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 4
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 1
Transfer Type Isochronous
Synch Type None
Usage Type Data
wMaxPacketSize 0x0000 1x 0 bytes
bInterval 4
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0009 1x 9 bytes
bInterval 4
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0011 1x 17 bytes
bInterval 4
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0019 1x 25 bytes
bInterval 4
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 2
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0021 1x 33 bytes
bInterval 4
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 2
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0031 1x 49 bytes
bInterval 4
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 5
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2 802.11ac NIC
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x08 EP 8 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 0 [unknown]
bDeviceSubClass 0 [unknown]
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
dimes - http://ix.io/4L0I
Looks like something happen lately with rtl8821cu driver. It is under investigation.
Please test again with this update:
It include the “latest” available driver for this chip.
Thanks. I am on 21 beta. I’m gonna give it some more time for team to fix it there ![]()
I will not until it’s tested. Please just boot and try it. Then the fix go also into ce-21.
Gotcha
I didn’t have any 20.x so I deployed the stable 20.2. I booted it up with the module plugged in, WLAN and BT worked out of the box.
Then I upgraded to the build you supplied, it’s still working good
Well, what’s interesting is that I came across an issue with TV Shows scraping, which doesn’t work at all, on any release, I installed the 21 build from tonight and WLAN works ok, as well as on yesterday’s build. So it looks like it’s working when one of the recent releases is installed, and not when it’s upgraded on top of previous ones.
Anyway, can anybody purge their TV shows library and set it up again? I’m loosing my mind… don’t know why it won’t fetch anything
2023-11-09 13:27:53.938 T:4902 warning : No information found for item ‘/storage/tvshows/The.Crowded.Room.S01E03.mkv’, it won’t be added to the library
I guess you got same hardware like here:
Update with the test image and make a dmesg | paste log.
Some T95W2 clone with S905W2 2Gb ram 16Gb rom
CoreELEC 21.0-Omega_beta1 installed
- Internal WiFi work (only in beta image) but it’s terrible slow
- External USB RTL8821CU not supported
lspci
dmesg
Hi! Bluetooth doesn’t work on my X96Max Plus Ultra. The chip is Fn Link K255B-SR C03043 (W155S1)
I use CoreELEC-Amlogic-ng.arm-21.0-Omega_nightly_20231206-Generic.img
mee to have H96 MAX W2
any news for wifi and bt driver ?
This is great piece of hardware at about 20€
nothing has changed, wifi and bt doesn’t work
I have a question whether wifi on this RTL8822BU usb chip will work with coreelec ?
Yes, since two weeks.
A post was merged into an existing topic: New Order: Looking for users with no working WiFi or BT
