Looking for users with no working WiFi or BT
Unkown chip…
KICKPI KP1 with MT7661RSN SDIO module. CoreELEC 22.0 NO is shipped with mt76 which include mt7663s driver (WiFi) and with project https://github.com/CoreELEC/MT7668 which include bt_mt7668 module with btmtk_sdio driver for mt7663s (Bluetooth).
I’m add firmware mediatek/mt7663pr2h.bin and mediatek/mt7663_n9_v3.bin from official mt76 project repo (binaries identical linux kernel firmware official repo) for mt7663s driver.
Also copy mediatek/mt7663pr2h.bin with name mt7663_patch_e2_hdr.bin to /storage/.config/firmware folder and EEPROM_MT7663.bin from /android/vendor/firmware wich requested btmtk_sdio driver. mt7663_patch_e2_hdr.bin and mediatek/mt7663pr2h.bin must be identical.
Wifi work well, Bluetooth work non stable (pair → crash interface) but paired BT-RCU and BT-headphones work.
udevadm info
P: /devices/platform/soc/fe088000.sdio/mmc_host/mmc2/mmc2:0001/mmc2:0001:1
M: mmc2:0001:1
R: 1
J: +sdio:mmc2:0001:1
U: sdio
V: mt7663s
E: DEVPATH=/devices/platform/soc/fe088000.sdio/mmc_host/mmc2/mmc2:0001/mmc2:0001:1
E: SUBSYSTEM=sdio
E: DRIVER=mt7663s
E: OF_NAME=wifi
E: OF_FULLNAME=/soc/sdio@fe088000/wifi@1
E: OF_COMPATIBLE_0=brcm,bcm4329-fmac
E: OF_COMPATIBLE_N=1
E: SDIO_CLASS=00
E: SDIO_ID=037A:7603
E: SDIO_REVISION=0.0
E: MODALIAS=sdio:c00v037Ad7603
E: USEC_INITIALIZED=8743064
E: ID_VENDOR_FROM_DATABASE=MediaTek Inc.
E: ID_SDIO_CLASS_FROM_DATABASE=Non-standard SDIO interface
P: /devices/platform/soc/fe088000.sdio/mmc_host/mmc2/mmc2:0001/mmc2:0001:2
M: mmc2:0001:2
R: 2
J: +sdio:mmc2:0001:2
U: sdio
V: btmtk_sdio
E: DEVPATH=/devices/platform/soc/fe088000.sdio/mmc_host/mmc2/mmc2:0001/mmc2:0001:2
E: SUBSYSTEM=sdio
E: DRIVER=btmtk_sdio
E: SDIO_CLASS=00
E: SDIO_ID=037A:7663
E: MODALIAS=sdio:c00v037Ad7663
E: USEC_INITIALIZED=8743199
lsmod
Module Size Used by
ir_rc6_decoder 20480 0
ir_nec_decoder 20480 0
meson_ir 20480 0
rc_core 90112 4 ir_rc6_decoder,ir_nec_decoder,meson_ir
amvdec_avs2_fb 356352 0
amvdec_av1_fb 270336 0
amvdec_h265_fb 290816 0
amvdec_vp9_fb 212992 0
amvdec_vp9 163840 0
amvdec_av1 196608 0
amvdec_vc1 94208 0
amvdec_mmpeg4 53248 0
amvdec_mmpeg12 77824 0
amvdec_mmjpeg 36864 0
amvdec_h266 937984 0
amvdec_h265 204800 0
amvdec_mh264 241664 0
amvdec_h264mvc 69632 0
amvdec_mavs 69632 0
amvdec_avs3 421888 0
amvdec_avs2 270336 0
stream_input 282624 13 amvdec_mh264,amvdec_av1_fb,amvdec_h265,amvdec_mavs,amvdec_avs3,amvdec_avs2_fb,amvdec_h265_fb,amvdec_vp9_fb,amvdec_h266,amvdec_mmpeg12,amvdec_avs2
decoder_common 507904 18 amvdec_av1,amvdec_mh264,amvdec_av1_fb,amvdec_vp9,amvdec_mmpeg4,amvdec_h265,amvdec_mavs,amvdec_avs3,amvdec_mmjpeg,amvdec_avs2_fb,amvdec_vc1,amvdec_h265_fb,stream_input,amvdec_vp9_fb,amvdec_h266,amvdec_mmpeg12,amvdec_h264mvc,amvdec_avs2
firmware 45056 19 amvdec_av1,amvdec_mh264,amvdec_av1_fb,amvdec_vp9,amvdec_mmpeg4,amvdec_h265,amvdec_mavs,amvdec_avs3,amvdec_mmjpeg,amvdec_avs2_fb,amvdec_vc1,amvdec_h265_fb,stream_input,amvdec_vp9_fb,decoder_common,amvdec_h266,amvdec_mmpeg12,amvdec_h264mvc,amvdec_avs2
media_clock 114688 20 amvdec_av1,amvdec_mh264,amvdec_av1_fb,amvdec_vp9,amvdec_mmpeg4,amvdec_h265,amvdec_mavs,amvdec_avs3,amvdec_mmjpeg,amvdec_avs2_fb,amvdec_vc1,amvdec_h265_fb,stream_input,firmware,amvdec_vp9_fb,decoder_common,amvdec_h266,amvdec_mmpeg12,amvdec_h264mvc,amvdec_avs2
pts_server 73728 14 amvdec_mh264,amvdec_vp9,amvdec_mmpeg4,amvdec_h265,amvdec_mavs,amvdec_avs3,amvdec_mmjpeg,amvdec_avs2_fb,amvdec_h265_fb,stream_input,decoder_common,amvdec_h266,amvdec_mmpeg12,amvdec_avs2
dm_mod 233472 16
mali_kbase 1220608 4
nfsd 847872 5
nfs_acl 20480 1 nfsd
bt_mt7668 258048 0
bluetooth 1032192 24 bt_mt7668
mt7663s 36864 0
mt76_sdio 28672 1 mt7663s
mt7663_usb_sdio_common 24576 1 mt7663s
mt7615_common 180224 2 mt7663_usb_sdio_common,mt7663s
mt76_connac_lib 57344 3 mt7663_usb_sdio_common,mt7615_common,mt7663s
mt76 135168 5 mt7663_usb_sdio_common,mt7615_common,mt7663s,mt76_sdio,mt76_connac_lib
nfnetlink 24576 1
autofs4 77824 0
dmesg
two type of error
IRQRatio___ERR.irq:2/IPI
IRQRatio___ERR.irq:42/fe088000.sdio
4-5 fault from dmesg - pairing BT-RCU throuth interface. fifth or sixth attempts are a success, RCU work well.
If I blacklisted bt_mt7668 module I have very rare errors:
IRQRatio___ERR.irq:42/fe088000.sdio action=meson_mmc_irq.0a8095b5723a0222e6d1bf1074ee95f0.cfi_jt ratio:5
Can anyone tell me how to disable onboard Bluetooth in sk1 please?
hi, cool guys,
I have a mini-TV-box(S905Y4、2G+8G、UWE5621DS ) work well in andriod11;
one day , i found Coreelec-ne20.5 can work use s4_s905y4_2g.dtb,but the wireless-device(unisoc UWE5621DS) not found,so i can‘t use wireless wifi。
  1. can some way add wireless-driver for UWE5621DS in coreelec boot(dtb file is need
    modify?);
  2. can add support “UWE5621DS” in new version coreelec-ne?
No driver available, no support.
A post was merged into an existing topic: New Order: Looking for users with no working WiFi or BT
Hey all, hope everyone is well. I am just playing with Coreelec and have flashed ot to my emmc on the SK1.
Although, i am having alwful issues with bluetooth and connecting the remote above.
I have even purchased a tp link bluetooth dongle that works with linx, but it still will not connect.
I know its not the remote as connects fine on Pi5 with libreelec and my FireCube3.
Anyone help at all?
https://paste.kodi.tv/izeterixir
If this helps at all atto?
Thanks so much in advance
Fyi, ignore this.
I deactivated sk1 bluetooth, and added external bluetooth, made sure that soft block was disabled.
All good now
Seems like Amlogic NE Kernel is missing RTL8821CS driver. I checked source tree and did not find it. Any plans to backport it from mainline? I have X98 S500 4/32 and it works well with generic DTB but lack WiFi driver. I installed CE onto eMMC to be able to use USB WiFi dongle via single USB port.
I have an issue with Bluetooth on X96 X10. RTL8852BE, UART HCI.
Identifies as RTL8852BS by rtk_hciattach.
21.2-Omega_nightly_20250620 (Amlogic-ne.aarch64)
When pairing the BLE remote, got this in dmesg.
[ 3362.987960@4]  hid-generic 0005:1D5A:C081.0004: unbalanced collection at end of report description
[ 3362.987979@4]  hid-generic: probe of 0005:1D5A:C081.0004 failed with error -22
Only 139 bytes of descriptor is read of total 197.
Remote is confirmed to work on other devices.
On ce-22 nightly, remote pairs successfully, but no event comes out of evdev.
When using USB HCI, everything works, so looks like HCI misconfiguration. Tried to use fw and config from stock Android, same result.
Any ideas?
Yes, one option is to start investigation and send soliution and will be included.
I’m not familiar with UART HCIs. Where is better to start investigation? Directly by hooking up to UART lines, or at some software level?
Chip in X96 X10 is labeled as RTL8852BE, and it’s listed as supported. Should it work out of the box in the first place?
Or it only relates to PCIe+USB version, but not to PCie+UART?
AFAIK, the only difference between RTL8852BS and RTL8852BE is UART instead of USB.
Thank you.
Same chip as sk1 and the only solution was usb dongle from ebay (6€). If you search here you’ll find Portish explaining that it’s some bluez compatibility (implementation) issue.
Understood, thank you!
Will look into BlueZ, and use USB HCI for now.
Good afternoon.
There is a transspeed m98 TV Stick with an s905y4 processor. Coreelec 21 is installed.
Neither Wi-fi nor Bluetooth are working.
The Wi-fi module in the Android system is identified as rtl8733bs.
I tried the following command with another external Wi-fi device:
udevadm info /sys/bus/sdio/devices/ | paste*
The result is:
https://paste.coreelec.org/BackwardOlive
Is there maybe some easy way to get this rtl8733bs running?
First ask the manufacturer to provide the source code of this driver.
I see one here and will try to get it compiled…
Nope, there is just too much different stuff included. Ask manufacturer for driver.
Thanks for trying. It’s a pity that it didn’t work out.
Maybe something will come out in the future…
RTL8733BS driver just added and should be available in tomorrow build CE-22 20250814 or later.
Thanks wifi is working on my x96 m200 but it doesn’t look there is a BT device showing with udevadm. Will it be possible?
You can enable tmate tomorrow and keep the device online. Then we can take a look.
https://wiki.coreelec.org/coreelec:term_share
OK thanks. I guess you would prefer I use your nightly not my self build I am running now. I am UTC -4 so will enable that after the nightly gets installed tonight.
