Thanks for the help. I have built and installed your recent changes and I now have BT on the x96 m200
CoreELEC-Amlogic-ne.aarch64-21.2-Omega-Generic
x96 x4 (s905x4) 4/32 1gbit. Internal Bluetooth - does not work, USB Asus BT400 - does not work. Tried 4 more different USB Bluetooth - does not work.
Adapters not found !
Thank you a lot, yes indeed Coreelec 22 started and the driver for wi-fi works successfully (2.4 Ghz and 5 Ghz, finds networks). When searching in Bluetooth, it says that “bluetooth adapters are not found”. I tried to turn it off and on, and also disabled various settings for bluetooth. As a result, it still did not start. For me, bluetooth is not critical, but if someone needs it in the future, then it does not work yet. Also, do not send me to the wrong topic to search for dtb for the s4_s905y4_1g device. Fake 2gb of RAM in the Trancespeed m98.
2 posts were merged into an existing topic: CE-22 NO: Looking for users with no working WiFi or BT
I have a Tanix TX3 mini with an unsupported wifi chip. I read this post and this post has a solution. But I don’t understand how to use this solution. I tried several old CoreElec releases (9.2.8, 19.5, 20.5). But non of them can detect this unsupported wifi chip. If this driver is disabled by default, how can I enable it? Anyone can explain to me? Thanks very much for any help.
A post was merged into an existing topic: CE-22 NO: Looking for users with no working WiFi or BT
Hi, do you know how to root MiBox S 2nd Gen and boot from usb device.
