Looking for users with no working WiFi or BT
I’m glad your happy :slight_smile:
Nice! I can confirm that it works with the ps3 controllers and the x96 Air box. Thank you a lot!!!
Hi, I’m a new user and my English is poor.
My box is Tanix TX3 Pro with S905W processor.
On CoreELEC 9.2.1 Wi-Fi works, Bluetooth does not work.
I connected the Bluetooth to USB adapter and it works correctly.
Then I installed CoreELEC Nigthly 20200330 but Bluetooth still does not work, also the Bluetooth USB adapter does not work.
The
udevadm info / sys / bus / sdio / devices / * | paste
command returns the following result:
P: /devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH = / devices / d0070000.sdio / mmc_host / sdio / sdio: 0001 / sdio: 0001: 1
E: DRIVER = rtl8723bs
E: SDIO_CLASS = 07
E: SDIO_ID = 024C: B723
E: MODALIAS = sdio: c07v024CdB723
E: SUBSYSTEM = sdio
E: USEC_INITIALIZED = 11822853
E: SYSTEMD_WANTS = rtkbt-firmware-aml.service
E: TAGS =: systemd:
Please help.!
Try a fresh install of the latest nightly but do not connect your USB dongle.
Hello.I didn’t want to open a new thread,so I write here for help.I have a vorke Z6,bluetooth sound to my home cinema works ok,but there is a problem on sound.When i watch movie,all sounds seems to be sound ok,except actors dialogs.Compared to whole movie sounds,they seem to have very low decibels.In point that in some cases I don’t even hear them!Anyone please a fix?Thanks in advance.
Please do not hijack this thread with such issues, this is for users who have NO WiFi or Bluetooth.
Is this valid also for uer with alpha -ng for 905X?
Alpha -ng GXL builds are not covered here.
Unfortunately, BT is still not working.
Nightly 20200331
L: 0
E: DEVPATH=/devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: DRIVER=rtl8723bs
E: SDIO_CLASS=07
E: SDIO_ID=024C:B723
E: MODALIAS=sdio:c07v024CdB723
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=11788575
E: SYSTEMD_WANTS=rtkbt-firmware-aml.service
E: TAGS=:systemd:
Sent you a PM.
should not be of any interest?
In the end the kernel is the same
I have a device with working BT and WiFi in non ng which does not work in -ng
No, those are community builds by cdu13a and are not official builds. If you choose to run them then you accept the consequences that come with them.
Hi, as I said, bluetooth is now working great in my box with the last nightly, but is it normal that each time that I reboot I need to connect the controllers again using the usb cable? Is it not saving the devices that you paired before?
This thread is for assisting users with NO WiFi or BT.
Sorry, I thought that the BT was still not working properly, but if you think that it is better, I am going to open a new post.
Mecool KM9 PRO 4GB RAM
WiFi OK BT not working: http://ix.io/2gtI
@kodiwpigulce_pl please provide the dmesg also from this device.
http://ix.io/2guy
A95 Max 4GB 64
Wlan ok BT NO
mfg
dmesg here http://ix.io/2gw5
@thecook you have the Mediatek 7668 chip, there is no compatible driver for the BT available.
