morka
1
HW info:
● Amlogic S905X CPU, quad core, Cortex A53
● Mali 450 GPU, penta-core, 750MHz
● 2GB DDR3L RAM + 16GB ROM
● 2.4GHz +5GHz dual band WiFi
● 100Mbps Ethernet
Using latest CoreElec 9.2.4.2, gxl_p212_2g.dtb
Boot from SD card without problem, but after installtointernal box not booting. After restart SD boot without problem.
I have few same boxes and without problem. Please help. Thank you
Which image did you use ??
CoreELEC-Amlogic.arm-9.2.4.2
or
CoreELEC-Amlogic-ng.arm-9.2.4.2
morka
3
CoreELEC-Amlogic.arm-9.2.4.2. I try also older version 9.2.1 witch works perfectly on previous devices.
installtointernal is not supported anymore.
Try Amlogic-ng and ceemmc.
morka
5
CoreELEC
CoreELEC (official): 9.2.4.2 (Amlogic-ng.arm)
CoreELEC:~ # ceemmc
Starting CoreELEC eMMC installation tool…
System is not supported: gxl_p212_2g!
Read the how-to more carefully.
I will close this topic now as the script in combination with this device is not supported for any internal install!
