Magicsee N5 MAX
Hi
SoC: Amlogic S905X3 Quad Core 4x ARM-A55 @ 1.9GHz (64bit) / GPU Mali-G31 MP2 / 12nm
System: Android 9 Pie (32bit)
Ram, storage and network:
– 4GB RAM DDR3 + 32/64/128GB eMMC / Wifi ac Dual + BT 4.2 / Ethernet Gigabit
– 4GB RAM DDR3 + 32/64/128GB eMMC / Wifi a/b/g/n Dual + BT 4.1 (SP6330) / Ethernet 10/100 (Review)
– 2GB RAM DDR3 + 16GB eMMC / Wifi b/g/n / NO Bluetooth / Ethernet 10/100
Ports: HDMI 2.1 4K@75fps / Jack AV / SPDIF / 1x USB 2.0 / 1x USB 3.0 / MicroSD / Reset
Extras: IR remote / HDMI cable / Manual / DC 5V 2A adapter
Materials and measures: Plastic / Frontal LED panel / 105 x 105 x 23 mm / 200 gr.
I have this device working fine on a micro sd, but I would like to install it on my device replacing android, I tried with installtointernal but it didn’t work. I’m new to this, could you help me?
