You have right, I feel stupid … I forgot for that simple thing.
But anyway, 100 Mbps ethernet has more bandwidht (real speed) than 60 Mbps, what I measured, am I right?
It could be better but that’s not always the case. If you are familiar with SSH and iperf3 you can run some tests in your network to see if you can get more from ethernet. In this kind of TV boxes you never know the quality of the components.
I recently got the N5 and was thinking of using it as standalone player using an external drive. I noticed that when you shut it down, the USB ports still have power which in turn keeps the external drive powered and running. I have a Mecool and if I shut it down, the usb ports are shut off also.
Is there a shut off command I can run at shutdown to turn power off the usb ports when I shut the N5 off? Or it’s just a setting I missed in coreelec?
Seems to be something they added in 9.2.0 for ODROID N2:
- added ability to turn on/off 5v power during power-off/sleep on ODROID-N2
Thanks!
This depends on the vendor uboot, and how it’s configured to handle USB when the device is shut down/put into standby. Not much we can do about that, as the N2 is running a custom bootloader, it was possible for us to add this capability to it.
Thank you for the clarification. Will probably just get another box like Meecool.
Hello guys, can you help me with this 2 problems please?
1. SSH problem - I have two same N5 boxes, but on one of them is not working SSH. In GUI is SSH turned on, but if I want connect to the box via Putty, I get error - connection refused. The both boxes was connected to the same network, so I assume, that problem is in the box. BTW, I remember, that during first installation of CoreELEC and during first setup wizard was not possible to turn on SSH. When I pushed the button to turn on SSH after that SSH button get back to OFF position, therefore I reinstall CoreELEC. Now SSH is on, but it is not working. Is there any change to restart or manually turn ON SSH from the box?
2. 4K videos (h264) - I have problem with playing videos with codec h264, video is stuttering. I have no problem with 4K videos h265, or HDR 4K h265 videos. I have no problem with network (buffering), but I thing, that problem is in HW decoding (h264).
I have setup everything by default, now I am running on CoreELEC 9.2.1.
Thank you for any help.
I have a problem with my MAGICSEE N5 2.4GHz version, the bluetooth doesn’t work. I ran this commands:
CoreELEC (official): 9.2.2 (Amlogic.arm)
CoreELEC:~ # /usr/bin/hciattach -n -s 115200 /dev/ttyS1 qca 2000000
wait_for_data: Timing out on select for 3 secs.
hci_send_vs_cmd: Failed to get HCI-VS Event from SOC
Failed to attach the patch payload to the Controller!
qca_soc_init: Fail to get Rome Version (0xffffff92)
Can’t initialize device: Success
CoreELEC:~ # hcitool dev
Devices:
CoreELEC:~ #
I think that the drivers is not present in the 9.2.2 release. I tried to connect an external USB bluetooth dongle but doesn’t work either.
I appreciate your help with this issue.
@jhortwo you have to cycle Bluetooth off and on and kill all other instances before running hciattach on a running system.
killall -9 hciattach
echo 0 > /sys/class/rfkill/rfkill0/state
echo 1 > /sys/class/rfkill/rfkill0/state
Hello, I have few minor problems with playing some videos with Magicsee N5 (coreelec stable 9.2.1 /9.2.2), but no issues during playing in internal player Samsung TV 65Q70R. So I suppose, that video files are ok, if Samsung TV has no problem with playing it.
If you need debug log, just tell me and I will log it.
Video files was played from external HDD connected through the usb to the N5 box.
1. Big Buck Bunny - 60fps, 4k
- Problem during playing from external hdd connected to the N5 - see photo
Media info - Big Buck Bunny
General
CompleteName : D:\bbb_sunflower_2160p_60fps_normal.mp4
Format/String : MPEG-4
Format_Profile : Base Media
CodecID/String : isom (isom/avc1)
FileSize/String : 642 MiB
Duration/String : 10 min 34 s
OverallBitRate/String : 8 488 kb/s
Movie : Big Buck Bunny, Sunflower version
Performer : Blender Foundation 2008, Janus Bager Kristensen 2013
Composer : Sacha Goedegebure
Genre : Animation
Encoded_Date : UTC 2013-12-17 16:40:26
Tagged_Date : UTC 2013-12-17 16:40:26
Comment : Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net
com : Jan Morgenstern
Video
ID/String : 1
Format/String : AVC
Format/Info : Advanced Video Codec
Format_Profile : High@L5.1
Format_Settings : CABAC / 4 Ref Frames
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 4 frames
CodecID : avc1
CodecID/Info : Advanced Video Coding
BitRate/String : 8 000 kb/s
BitRate_Maximum/String : 35.1 Mb/s
Width/String : 3 840 pixels
Height/String : 2 160 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Constant
FrameRate/String : 60.000 FPS
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.016
StreamSize/String : 605 MiB (94%)
Encoded_Library/String : x264 core 120
Encoded_Library_Settings : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x133 / me=tesa / subme=11 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=8000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.60
Tagged_Date : UTC 2013-12-17 16:40:29
CodecConfigurationBox : avcC
Audio #1
ID/String : 2
Format/String : MPEG Audio
Format_Version : Version 1
Format_Profile : Layer 3
Format_Settings : Joint stereo / MS Stereo
CodecID : mp4a-6B
BitRate_Mode/String : Constant
BitRate/String : 160 kb/s
BitRate_Maximum/String : 165 kb/s
Channel(s)/String : 2 channels
SamplingRate/String : 48.0 kHz
FrameRate/String : 41.667 FPS (1152 SPF)
Compression_Mode/String : Lossy
StreamSize/String : 12.1 MiB (2%)
Encoded_Library/String : LAME3.99r
Encoded_Library_Settings : -m j -V 4 -q 3 -lowpass 17.5 -b 160
Encoded_Date : UTC 2013-12-17 16:40:28
Audio #2
ID/String : 3
Format/String : AC-3
Format/Info : Audio Coding 3
Format_Commercial_IfAny : Dolby Digital
CodecID : ac-3
BitRate/String : 320 kb/s
Channel(s)/String : 6 channels
ChannelLayout : L R C LFE Ls Rs
FrameRate/String : 31.250 FPS (1536 SPF)
StreamSize/String : 24.2 MiB (4%)
ServiceKind/String : Complete Main
2. The Expanse S04 - 4k, h264 - video stuttering, frames skip
Media info - The Expanse
General
UniqueID/String : 272633005061078824672564858508339438265 (0xCD1B34F2A653E05F5B4A7585A16DE2B9)
CompleteName : D:\The.Expanse.S04E01.2160p.AMZN.WEBRip.DDP5.1.x264-NTb.mkv
Format/String : Matroska
Format_Version : Version 4
FileSize/String : 10.0 GiB
Duration/String : 49mn 17s
OverallBitRate/String : 29.1 Mbps
Encoded_Date : UTC 2019-12-15 16:39:59
Encoded_Application/String : mkvmerge v32.0.0 (‘Astral Progressions’) 64-bit
Encoded_Library/String : libebml v1.3.7 + libmatroska v1.5.0
Video
ID/String : 1
Format/String : AVC
Format_Settings : CABAC / 5 Ref Frames
Format_Settings_RefFrames/String : 5 frame
CodecID : V_MPEG4/ISO/AVC
BitRate/String : 28.4 Mbps
Width/String : 3840 pixel
Height/String : 2160 pixel
FrameRate_Mode/String : CFR
FrameRate/String : 23.976 (24000/1001) fps
ColorSpace : YUV
Bits-(Pixel*Frame) : 0.143
StreamSize/String : 9.80 GiB (98%)
Encoded_Library/String : x264 core 157 r2969 d4099dd
Encoded_Library_Settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.30 / pb_ratio=1.20 / aq=3:0.80
Language/String : en
Default/String : Yes
Forced/String : No
Audio
ID/String : 2
Format/String : E-AC-3
Format/Info : Enhanced AC-3
Format_Commercial_IfAny : Dolby Digital Plus
CodecID : A_EAC3
BitRate_Mode/String : CBR
BitRate/String : 640 Kbps
SamplingRate/String : 48.0 KHz
FrameRate/String : 31.250 fps (1536 SPF)
StreamSize/String : 226 MiB (2%)
Forced/String : No
Text #1
ID/String : 3
Format/String : UTF-8
CodecID : S_TEXT/UTF8
CodecID/Info : UTF-8 Plain Text
Duration/String : 46mn 37s
BitRate/String : 91 bps
ElementCount : 533
StreamSize/String : 31.4 KiB (0%)
Language/String : ar
Default/String : No
Forced/String : No
Text #2
ID/String : 4
BitRate/String : 54 bps
ElementCount : 528
StreamSize/String : 18.6 KiB (0%)
Language/String : da
Default/String : No
Forced/String : No
Text #3
ID/String : 5
Duration/String : 46mn 36s
BitRate/String : 47 bps
ElementCount : 411
StreamSize/String : 16.2 KiB (0%)
Language/String : de
Default/String : No
Forced/String : No
Text #4
ID/String : 6
Duration/String : 47mn 6s
BitRate/String : 61 bps
ElementCount : 765
StreamSize/String : 21.1 KiB (0%)
Title : SDH
Default/String : No
Forced/String : No
Text #5
ID/String : 7
BitRate/String : 55 bps
ElementCount : 533
StreamSize/String : 19.0 KiB (0%)
Title : Latinoamérica
Language/String : es
Default/String : No
Forced/String : No
Text #6
ID/String : 8
BitRate/String : 56 bps
ElementCount : 529
StreamSize/String : 19.4 KiB (0%)
Title : España
Default/String : No
Forced/String : No
Text #7
ID/String : 9
BitRate/String : 53 bps
ElementCount : 530
StreamSize/String : 18.1 KiB (0%)
Language/String : fi
Default/String : No
Forced/String : No
Text #8
ID/String : 10
ElementCount : 534
Language/String : fr
Default/String : No
Forced/String : No
Text #9
ID/String : 11
BitRate/String : 83 bps
ElementCount : 535
StreamSize/String : 28.4 KiB (0%)
Language/String : he
Default/String : No
Forced/String : No
Text #10
ID/String : 12
BitRate/String : 146 bps
ElementCount : 535
StreamSize/String : 50.1 KiB (0%)
Language/String : hi
Default/String : No
Forced/String : No
Text #11
ID/String : 13
BitRate/String : 46 bps
ElementCount : 533
StreamSize/String : 16.0 KiB (0%)
Language/String : id
Default/String : No
Forced/String : No
Text #12
ID/String : 14
BitRate/String : 57 bps
ElementCount : 534
StreamSize/String : 19.5 KiB (0%)
Language/String : it
Default/String : No
Forced/String : No
Text #13
ID/String : 15
BitRate/String : 43 bps
ElementCount : 469
StreamSize/String : 14.9 KiB (0%)
Language/String : ja
Default/String : No
Forced/String : No
Text #14
ID/String : 16
ElementCount : 535
StreamSize/String : 19.7 KiB (0%)
Language/String : ko
Default/String : No
Forced/String : No
Text #15
ID/String : 17
BitRate/String : 52 bps
ElementCount : 532
Language/String : nb
Default/String : No
Forced/String : No
Text #16
ID/String : 18
BitRate/String : 50 bps
ElementCount : 528
StreamSize/String : 17.1 KiB (0%)
Language/String : nl
Default/String : No
Forced/String : No
Text #17
ID/String : 19
BitRate/String : 51 bps
ElementCount : 527
StreamSize/String : 17.7 KiB (0%)
Language/String : pl
Default/String : No
Forced/String : No
Text #18
ID/String : 20
ElementCount : 530
StreamSize/String : 18.0 KiB (0%)
Language/String : pt
Default/String : No
Forced/String : No
Text #19
ID/String : 21
BitRate/String : 97 bps
ElementCount : 532
StreamSize/String : 33.2 KiB (0%)
Language/String : ru
Default/String : No
Forced/String : No
Text #20
ID/String : 22
ElementCount : 534
StreamSize/String : 18.7 KiB (0%)
Language/String : sv
Default/String : No
Forced/String : No
Text #21
ID/String : 23
BitRate/String : 170 bps
ElementCount : 535
StreamSize/String : 58.3 KiB (0%)
Language/String : ta
Default/String : No
Forced/String : No
Text #22
ID/String : 24
BitRate/String : 153 bps
ElementCount : 535
StreamSize/String : 52.5 KiB (0%)
Language/String : te
Default/String : No
Forced/String : No
Text #23
ID/String : 25
BitRate/String : 147 bps
ElementCount : 535
StreamSize/String : 50.4 KiB (0%)
Language/String : th
Default/String : No
Forced/String : No
Text #24
ID/String : 26
ElementCount : 534
StreamSize/String : 17.4 KiB (0%)
Language/String : tr
Default/String : No
Forced/String : No
Text #25
ID/String : 27
BitRate/String : 48 bps
ElementCount : 533
StreamSize/String : 16.5 KiB (0%)
Title : 中文(简体)
Language/String : zh
Default/String : No
Forced/String : No
Text #26
ID/String : 28
ElementCount : 534
StreamSize/String : 15.9 KiB (0%)
Title : 中文(繁體)
Default/String : No
Forced/String : No
Menu
00:00:00.000 : en:Amazon Original
00:00:05.000 : en:Previous Season
00:01:35.000 : en:Opening Credits
00:02:43.000 : en:Blockade running
00:05:00.000 : en:The next clue to the case
00:08:32.000 : en:A call from Peaches
00:11:34.000 : en:The investigator gets his wish
00:15:03.000 : en:The roci and her crew prepares for the long haul
00:17:02.000 : en:Bobbie tries to settle in
00:21:20.000 : en:A pirate’s perspective
00:24:40.000 : en:Belter determination
00:26:01.000 : en:The Roci flies by Medina Station
00:29:52.000 : en:Trading war stories
00:31:50.000 : en:My friend had a boyfriend with an imaginary friend
00:33:32.000 : en:Ilus v. New Tera
00:38:59.000 : en:Down the well
00:44:27.000 : en:Traitors or saviors
00:47:04.000 : en:End Credits
3. Gemini man - 4k, h265, HDR - video stuttering, frames skip
Media info - Gemini Man
General
Unique ID : 198290021965411148308749213155926607085 (0x952D44E395361B35A66E16F2AFDE04ED)
Complete name : D:\Gemini.Man 2160p.mkv
Format : Matroska
Format version : Version 2
File size : 74.0 GiB
Duration : 1 h 57 min
Overall bit rate mode : Variable
Overall bit rate : 90.5 Mb/s
Movie name : Gemini.Man.2019.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT
Encoded date : UTC 2020-01-25 11:01:19
Writing application : mkvmerge v3.3.0 (‘Language’) built on Mar 24 2010 14:59:24
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Cover : Yes
Attachments : small_cover.jpg / small_cover_land.jpg / cover.jpg / cover_land.jpg / cover.jpg
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Title : Gemini.Man.2019.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 5180 cd/m2
Maximum Frame-Average Light Level : 1577 cd/m2
Duration_Source : General_Duration
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Maximum bit rate : 7 944 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Language : English
Default : No
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Channel(s) : 6 channels
Channel(s)_Original : 8 channels
ChannelLayout_Original : C L R LFE Lsr Rsr Lss Rss
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Default : No
Forced : No
Audio #3
Format : AC-3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 536 MiB (1%)
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Stream size : 375 MiB (0%)
Language : Czech
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Czech
Default : No
Forced : No
4.General problem during playing any video - If I will try play some video during playing some other video (without stoping the first video), the whole kodi will stuck and only hard reset (plug off) will help.
If those problems are some hardware (performance) issue, then I have no problem to buy better tv box. Otherwise I will be thankfull for some help.
I owned a magicsee N5 905x box and it’s a low end device. Don’t expect too much from it. But those are too many problems. Did you try a fresh install?
Not yet. Everything works fine with this box . During 1 year of using this box I found only those issues on that video files. Do you thing, that fresh install should help?
BTW, I have coreelec installed on eMMC, so what is the fastest way to do fresh install of coreelec?
EDIT 1:
I assume, that the best way how to do fresh install is the standard way via SD card and then transfer to emmc/nand memory of the box. But one thing is for me not clear. During transfer coreelec from sd card to emmc will the files on emmc remain? If yes, how I can delete / format whole emmc before transfering fresh coreelec from sd card? Can I do this?
Or is there any wiser way how to do fresh install?
Thank you for help.
I try those commands but still not working:
CoreELEC:~ # killall -9 hciattach
killall: hciattach: no process killed
CoreELEC:~ # echo 0 > /sys/class/rfkill/rfkill0/state
CoreELEC:~ # echo 1 > /sys/class/rfkill/rfkill0/state
CoreELEC:~ #
Same thing for my Magicsee N5 even with a fresh install
Are you sure it’s a Qualcomm chipset in your device?
I’m not sure if there is a Qualcomm chipset but I pluged a USB Bluettoth Dongle. Without the dongle the output is:
Devices:
CoreELEC:~ #
That command is for Qualcomm chipsets ONLY, the clue is in qca, you should not be entering commands that you don’t know.
Enter the following and paste the output please.
udevadm info /sys/bus/sdio/devices/*
In CoreELEC settings, you need to untick “Disable GUI scaling” and reboot.
It’s not a Magicsee N5 problem.
Ah this is not needed on boxes running the 3.14 kernel builds.
In either case, it’s a hardware limitation when the GUI is rendered at 4k@30<. On 3.14 kernel GUI is always rendered at up to 1080P, so I don’t know what’s going on with your device.
Will it help, if I will send a log with this problem?
I also want to try fresh install of coreelec, but can I delete everything from emc, what I can see in file manager in kodi? Or how can I delete everything from whole tv box N5?
