Is it possible to use config.ini on generic S905W?
adamg said that it only works with dev boards
I would like to turn on the box with MCE RC6 remote. I got the remotewakeup=‘0x800f040c’ code using ir-keytable -u
Does anyone has any tips on how to enable config.ini on generic X905W devices and to recompile the image?
I have read through https://libreelec.wiki/compile and I’m guessing that i need to update projects/Amlogic/linux/linux.aarch64.conf Disable splashscreen, enable detailed boot console
Thank you
It’s not possible with vendor u-boot.
Which part? Enable Config.ini or updating projects/Amlogic/linux/linux.aarch64.conf? My guess is both…
How about updating CONFIG_IR_REMOTE_POWER_UP_KEY_VAL4 in https://github.com/khadas/u-boot/blob/69eb192a445cd1d485954175a18b46b152bd7abd/board/amlogic/configs/gxl_p212_v1.h ?
Or am I completely on the wrong track?
Thank you
Right now it’s not possible. I work on a solution for this. But first g12a/b, GXL/GXM, gxb,…
If you don’t mind me asking what kind of solution? Would there be a possibility to add our own IR_REMOTE_POWER_UP_KEY or something similar?
Thank you
Yes, full support for config.ini. it’s already a undocumented part of the Beelink GT King.
When I finished the implementation I will write a how-to.
Thank you so much. I have a spare X96 Mini if you need some tests done on a Generic S905W. I don’t mind bricking one for testing…
