I’m trying to install CoreElec on my new KI pro. I prepared the SD and with the toothstick it begins to install. However, when it reboots, it stuck on Mecool logo…
After several attempts changing the dvb.img and more, i created a USB flash as the same way…My surprise is with the USB it works.
Is strange because if I boot the native Android OS and I introduce the SD, it recognizes it and I can see the files on the explorer, but is not working to install/boot
I’m using gxl_p230_k1_pro. I think is not the problem as I created an USB with the same procedure and dtb and it’s working. Is a problem with the SD only. I’ve seen two users who have solved it with tape, so i think is a hardware problem in KI Pro…
just cut a piece of adhesive tape of the same size as the SD card and stick it to the SD card. Then check if the box is booting. If not, repeat the procedure mentioned in the first sentence.
