Hi community,
kindly asking for your help to get a correct device tree for the following device:
Meelo UNO S905 with DVB-T2/S2 tuner
CPU: S905
RAM: 1G
FLASH: 8G
eth: 100mbit
Tuners: Availink AVL6862TA | Rafael Micro R912
Many thanks
Mike
Hi community,
CPU: S905
RAM: 1G
FLASH: 8G
eth: 100mbit
Many thanks
Mike
Try gxbb_p200_k1_plus.dtb
Wonderful, thank you so much. Device is running, tuners are tuning, so far no problems detected.
Thanks again, really appreciate your help.
Cheers
Mike
Maybe a good idea would be to add the device to the device list now?
Mike
If anyone is thinking of buying one of these for using it as a dual tuner it isn’t. The tuner only has one front end you can use either DVB-S/2 or DVB-T/2 but you cant use both at the same time. I bought it to replace my box and two XBOX tuners only to find I can only use one mux at a time.
Hola afl1, me podrias explicar un poco los pasos y versiones para intentar lo? Tmb tengo el meelo uno 2 y no tengo ****, de que arranque con coreeles
Gracias
Hi, afl1 isn’t around and this is an english only forum. Please try the dtb afl1 mentioned above, the one for the k1 plus.
Hola yo tampoco soy capaz de instalar coreelec en meelo + uno2, puedes dar mas información? Ademas e probado varios firmware android de los suyos y varios de k1+ con datos inteligente que en KII PRO van bien y en meelo uno2 me sale Mezclar canal, alguna solución? Gracias
just looking for a confirmation whether this device can be upgraded to Coreelec19 or not. The CPU is internally detected as S905H rev c and Mali-450 MP graphics card.
I tried various 1G DTBs supplied with the generic image, but none of them seem to be working.
Myso
See here the answer: CoreELEC 19.4-Matrix_rc2 Discussion - #160 by bhf
S905H is GXBB family, which has been dropped, so will not work with CE19
