jimm
29 July 2023 14:44
#1
Hello, I am a user of mibox s 2nd (mdz_28_aa).
I saw that homatics can boot coreelec from a USB drive, and since the CPU of mibox s 2nd is the same, I tried to boot coreelec from a USB drive. However, I couldn’t start it, and I received the following error message:
'### Starting debugging shell for boot step: mount_flash… type exit to quit ###
*** Error in mount_flash: mount_common: Could not mount LABEL=COREELEC ***
jimm
30 July 2023 14:40
#3
I’ve tried two USB sticks, one of which is newly purchased, and both of them display this error.
You are making usb stick correctly?
jimm
30 July 2023 14:49
#5
I am making usb stick correctly. I used both balenaEtcher and Rufus.
I’m just guessing what can be wrong but do you have any stick with led to see if maybe usb is not powered when you see this message?
jimm
30 July 2023 14:58
#7
When my TV box starts up, the LED on the USB stick blinks for a while. when I see this message, the LED on the USB stick stops blinking.
Maybe the usb power got cut. Which means it doesn’t allow booting from usb.
Original box didn’t allow booting CoreELEC: Xiaomi Mi BOX - CE and DRM
But I think I saw somewhere how to boot from this device but can’t find the source.
Or this was mibox3? Reddit - Dive into anything
jimm
30 July 2023 15:29
#9
Thank you for your help.I will continue to try.
I have Xiaomi old box Chinese only.
MDZ- 18-AA.
Havd you tried to boot CoreELEC from recovery
Remove power supply from box.
Insert USB Drive with CoreELEC
Now must hokd in 2 button’s on remote control at same time…
The OK button and BACK button
Continue holding and apply power to box.
Keep holding button until CoreELEC boots
Or you are taken to recovery
Maybe will work
Happy Testing
