I’m having the same issue as the topic below:
Rii i25 + Minix Neo U1 - Help & Support / Remote Controllers - CoreELEC Forums
My Rii i25 remote control works fine when the USB receiver is re-connected, however upon reboot it stops working and I have to disconnect then reconnect the USB receiver to get it working again.
Is there somehow I can get this work work without having to reconnect the dongle every time I want to use the remote?
I should also note that when running lsusb the Rii i25 USB device isn’t listed, but it is functioning:
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I then reconnect the USB device and run lsusb again to get this output:
Bus 001 Device 008: ID 1915:1028 Nordic Semiconductor ASA
I’d be happy if there was a way to reconnect the USB device using autostart.sh
Thanks.
