Missing partition 'super' on eMMC
There is no option to enable terminal sharing in the 20.3ng nightly version. I used the 20.2 version before and enabled terminal sharing. Please kindly deal with it when you are free.
@vpeter
This will not work because the problem is with NG.
I think this issue will stay unresolved for now.
Ok, then look at it later I plan to manually create the corresponding directory, I do not know whether it is OK, I will test it later, by the way to find the information, thank you.
Making folder will not help because the problem is that vendor partition is not found for some reason. Which means dovi module can’t be loaded.
Could you please send me the mounting command? In addition, tell me the directory where dovi needs to be mounted under Android system, I will look for it myself and see if I can find it. If it is done, I will feed back to you. Is it OK for you? I’m in trouble.
I hope this picture is helpful, please.
After playing the video for a period of time, the problem has appeared before, the volume will become smaller and mute, I would like to ask if I have to execute the two commands sent to me yesterday and restart it every time I start.
link see: http://ix.io/4FI4
It may be caused by my online update today to today’s nightly edition, I just re-typed yesterday’s two commands and restarted, I will see under the test.
CoreELEC:/ # df -h
Filesystem                Size      Used Available Use% Mounted on
devtmpfs                  1.8G      4.0K      1.8G   0% /dev
tmpfs                   752.8M     14.6M    738.2M   2% /run
/dev/sda1               511.7M    233.1M    278.6M  46% /flash
/dev/loop0              212.0M    212.0M         0 100% /
/dev/sda2                13.5G     10.1M     13.5G   0% /storage
tmpfs                     1.8G         0      1.8G   0% /dev/shm
tmpfs                     4.0M         0      4.0M   0% /sys/fs/cgroup
tmpfs                     1.8G      2.1M      1.8G   0% /var
tmpfs                     1.8G         0      1.8G   0% /tmp
Again try with this dtb and if it works I will push the changes and will not get overwritten with the update.
It is hard to follow you if you are mixing images. What exactly are you using?
I understand. Let’s not solve the mounting problem for the time being. I will go back and test the new dtb file.
After testing for some time, the new dtb file can work normally, thank you.
Hello, after a period of testing and feedback, it can now be used normally. The current issue is that there is no WiFi or Bluetooth, and the dovi.ko file cannot be loaded. All other issues have been resolved. I greatly like you here.
I hope the next version of the new installation, to solve my previous problem, the problem of small volume, instead of using the dtb file you compiled yesterday.
Hello, please do a test image to test my dovi.ko, yesterday’s error, the reason is that the mounting partition error, I read today, should mount odm partition, dovi.ko path is odm\lib\modules\dovi.ko
@vpeter
Then first try if you can even mount odm partition in CE with command
mount -o ro /dev/odm /android/vendor
find /android/vendor -name dovi.ko
But I’m sure this will not work because there are multiple issues: you device Android dovi.ko is compatible only with CoreELEC NE release and not NG. Which means dovi will not work with NG image.
Why do you even use NG image and not NE?
As long as he doesn’t report any errors, I don’t care if he supports dv in the end. I just need him to load dovi.ko normally. Thank you again. When I go back to test tonight, I will also try the ne21 version. By the way, the Android system will be updated later. Let’s see then.
Then just ignore this dovi loading issue - problem solved. You obviously don’t need DV so why do you care so much of this error loading it? It can’t be loaded and problem can’t be solved in NG.
Then I understand this error, this error is a normal phenomenon in ng package, if it is, I will ignore this error, sorry to trouble you, then I hope the next version, do a new installation, can solve the problem of small volume, thank you for your trouble.
Hello, may I ask you to update the 20ng version online later, and you do not need to manually overwrite the dtb file you sent me yesterday?
CoreELEC (official): 21.0-Omega_nightly_20230909 (Amlogic-ne.aarch64)
      Machine model: Amlogic
     CoreELEC dt-id: sc2_s905x4_4g_1gbit
CoreELEC:~ # dmesg | paste
http://ix.io/4FOQ
CoreELEC:~ # systemctl status opentee_linuxdriver.service -l --no-pager | paste
http://ix.io/4FOR
CoreELEC:~ # journalctl -l | paste
http://ix.io/4FOS
CoreELEC:~ # ce-debug
http://ix.io/4FOT
CE20 NE doesn’t boot?
I did not test ce20 ne Oh, before the test, boot flower screen, did not get, I got ce20 ng.
It would be great if the NE version, regardless of which TV set it is on, does not cause screen flicker when turned on. Currently, the NG version and the NE. arm version do not have screen flicker, and the NE screen flicker can only be replaced on a 4K TV to prevent screen flicker. I have previously provided feedback that the TV equipment needs to be replaced. What I am saying this time is that I hope to solve the problem of screen distortion. Thank you.
