I just got my got my N2 CoreElec edition and upgraded to 9.2.1
I have kept the resolution at 1080 in the menu, if I change this to 4k it zooms so I can only see 1/4 of the screen, see the image I uploaded
Then I ran the Video calibrate and the menu now fits on my 4K TV
But when I enter a 720p/1080p movie it seems a bit and do not use the calibrate I just did
If I enter a 4k movie its zooms as if I changed the menu to 4k and I can only see part of the movie
Side note: When I enter a movie, the tv will flickr and then display “HDMI 2” (Which it was already on) indicating that something about the input has changed
My tv is https://www.panasonic.com/dk/consumer/smart-tv/4k-pro/tx-75fx780e.html with a Sony HT-ST5000 soundbar that my N2 is connected to
