Greetings,
Would be nice if you could generate Berryboot squashfs images for each ARM-Box releases (a bit like CE, LE, OE and Dev Builds are doing).
This is very convenient for testing and having multiple distributions on same SD card.
More info can be found https://www.berryterminal.com/doku.php/berryboot/adding_custom_distributions and https://www.berryterminal.com/doku.php/berryboot .
Best regards…
You have completely lost me here?
Greetings,
My dear friend; how is that sentence?
You are very valuable to me, now I do not use anyone other than CE.
I say that; I want to use other develop versions on the same card without touching the main release (8.90.2).
Best regards…
Poida
16 May 2018 10:53
4
Just buy another SD card. FYI, CE, CE dev builds are NOT doing this
Berryboot was designed for the RPi, I guess using something like this may be possible but it’s not something that I personally have the time to look into at the present.
If someone gets it working it would be interesting to try.
Hopefully someone will have the time and inclination.
Greetings,
We are very happy if a expert coder or a software developer is doing a study on this.
Best regards…
You can already run 1 installation from internal and 1 from external and boot between the 2.
Greetings,
How do I install the CE image in the eMMC section of Mecool K1 Pro?
Best regards…
Not supported. You can use Kszaq’s LE method installtointernal command via ssh but no support if it goes pear shape.
Use the internal data recipe below.
I found this post by kszaq to be very useful, as it combines the convenience of dual boot with speed of internal installation while retaining the safety of booting from external media.
A word of caution:
Be aware, as you would have heard before ’with power comes responsibility’ and altering the default storage location of these builds is no different.
Once you have employed any procedure that changes the default partition layout of these builds, it is entirely your own responsibilty to rememb…
tosa
20 May 2018 10:22
11
WOW !!!
I really want that.
Is it possible to make this comptible for non-RPi devices?
@anon88919003 @Ray ???
SSH: installtointernal
tosa
20 May 2018 11:02
13
Thank you, but I can read …
@anon88919003 has no time for that.
This is not a statement for me, if there would possibly dare any other ran. I say that so @Ray and @anon88919003 register that I would be interested in this feature. The more that say, the more likely someone will dare …
Lg Tommy
Poida
20 May 2018 11:39
14
LOL. Oh, I see the strategy. Keep on until they do it
tosa
20 May 2018 11:59
15
And that is funny? LOL, yeah that’s funny
