Hi Everyone,
A while ago i bought a MXQ Pro 4k (worst android player ever)
Now i have a install sd card with
Libreelec ver 20200427213119-b7186bc
Arch: RK322x.arm
i tried to config my remote following this tutorial
IR remote controls can be configured in 1 of 2 ways in CoreELEC, both are detailed in this guide below.
meson-ir
meson-ir allows you to use almost any IR remote controller to control your device.
CoreELEC uses meson-ir by default and our builds come with a limited selection of IR remote configurations for devices built in.
If your remote does not work then you will need to follow the below instructions to create a config and get it working.
Firstly you must SSH into your device and then Kod…
i made my own remote.cfg file (cant upload it because i am new user)
table mecool, type: NEC
0x14e KEY_1
0x10d KEY_2
0x10c KEY_3
0x14a KEY_4
0x109 KEY_5
0x108 KEY_6
0x146 KEY_7
0x105 KEY_8
0x104 KEY_9
0x101 KEY_0
0x14c KEY_MENU
0x55 KEY_CHANNELUP
0x15 KEY_CHANNELDOWN
0x118 KEY_VOLUMEUP
0x110 KEY_VOLUMEDOWN
0x111 KEY_HOME
0x150 KEY_RIGHT
0x151 KEY_LEFT
0x116 KEY_UP
0x11a KEY_DOWN
0x113 KEY_ENTER
0x141 KEY_MUTE
0x119 KEY_BACK
0x KEY_INFO
0x44 KEY_STOP
0x08 KEY_PREVIOUSSONG
0x0b KEY_NEXTSONG
0x59 KEY_POWER
0x4a KEY_REWIND
0x48 KEY_FASTFORWARD
0x46 KEY_PLAYPAUSE
0x1f KEY_FAVORITES
0x4d KEY_EPG
0x04 KEY_RECORD
0x51 KEY_ESC
0x143 KEY_RED
0x40 KEY_GREEN
0x00 KEY_YELLOW
0x03 KEY_BLUE
0x01 KEY_LANGUAGE # audio
0x09 KEY_SUBTITLE # subtitle
0x100 KEY_CONTEXT_MENU # mouse
0x11 KEY_COMPOSE # DTV
0x10f KEY_CONFIG # APPS
0x18 KEY_TEXT # BROWSER
I placed this Cfg file into the map
/storage/.config/rc_keymaps
And now i am bit stuck, i need to do this
"You must also create the following file /storage/.config/rc_maps.cfg with the following contents.
meson-ir * YOURMAPNAME"
But i have no idea what i really need to do
Can someone please help me out a bit?
Just look under Library\Samples\RC Maps\
Trekdrop:
Arch: RK322x.arm
Are You running CoreElec or LibreElec ?
Thank you for your reply, sorry for my late reply. Trying to get this running but its not woking.
Arch: RK322x.arm
So this is what i have.
In
I have re_maps.cfg with the text
gpio_ir_recv * Remote
in
i have a map with the name: Remote
In
/storage/.config/rc_keymaps/Remote
I have a file: Remote.cgf
With:
0x14e KEY_1
0x10d KEY_2
0x10c KEY_3
0x14a KEY_4
0x109 KEY_5
0x108 KEY_6
0x146 KEY_7
0x105 KEY_8
0x104 KEY_9
0x101 KEY_0
0x14c KEY_MENU
0x55 KEY_CHANNELUP
0x118 KEY_VOLUMEUP
0x111 KEY_HOME
0x150 KEY_RIGHT
0x151 KEY_LEFT
0x116 KEY_UP
0x11a KEY_DOWN
0x113 KEY_ENTER
0x141 KEY_MUTE
0x119 KEY_BACK
0x KEY_INFO
0x44 KEY_STOP
0x0b KEY_NEXTSONG
0x59 KEY_POWER
0x4a KEY_REWIND
0x46 KEY_PLAYPAUSE
0x1f KEY_FAVORITES
0x4d KEY_EPG
0x04 KEY_RECORD
0x51 KEY_ESC
0x143 KEY_RED
0x40 KEY_GREEN
0x00 KEY_YELLOW
0x03 KEY_BLUE
You are asking in CoreElec Forum about LibreElec.
Better ask in LibreElec Forum.
