New Order: Looking for users with no working WiFi or BT
CoreELEC (official): 21.0-Omega_nightly_20240322 (Amlogic-ne.aarch64)
Machine model: Amlogic
CoreELEC dt-id: sc2_s905x4_4g_1gbit
CoreELEC:~ # udevadm info /sys/bus/pci/devices/* | paste
Unknown device “/sys/bus/pci/devices/*”: No such device
https://paste.coreelec.org/GJYjcI
CoreELEC:~ # lspci | paste
https://paste.coreelec.org/86NwoX
CoreELEC:~ # dmesg | paste
https://paste.coreelec.org/w7TxdM
CoreELEC (official): 20.5-Nexus (Amlogic-ng.arm)
mount -o rw,remount /flash
fdtput -t s /flash/dtb.img /pcieA@f5000000 status okay
sync
reboot
https://paste.coreelec.org/Ex5nnp
-sh: lspci: not found
https://paste.coreelec.org/LZYvd0
https://paste.coreelec.org/d40Ehv
no bt and no wifi
I doubt anything was done in this are so there is no chance to make it better.
That means I can’t adapt to my device’s wireless and Bluetooth, right?
When someone get time he can look into it. But now we are busy…
Do you have time to handle it? Thank you for bothering you.
How many times you need same answer ??? This is just one of the issues and not everything can be solved asap. Some just needs more time and some are just impossible to fix.
Beelink GT-King
The Wifi section has disappeared
21.0-Omega_nightly_20240308 (CoreELEC-Amlogic-no.aarch64-21.0-Omega_nightly_20240308.tar)
21.0-Omega_nightly_20240322 (CoreELEC-Amlogic-no.aarch64-21.0-Omega_nightly_20240322.tar)
wifi section gone
but on all previous versions everything was fine
21.0-Omega_nightly_20240304 (CoreELEC-Amlogic-no.aarch64-21.0-Omega_nightly_20240304.tar)
Confirmed. Will be fixed soon.
@tht can you please get a device online with Amlogic-no and WiFi chip 02D0:433 by tmate?
tht-2 is online
No, the driver I tested looks like have same issue.
Will need to think about.
@blueyeti2000 you can try now CoreELEC nightly builds with new Kinhank DTB if Wifi start working. If not please provide logs as usual.
Or tomorrow there will be Amlogic-ne CE-21 available as well.
Amlogic-no do not have Dolby Vision support as no dovi.ko for kernel 5.15 does exists yet.
EDIT: Amlogic-no pcie driver does not yet work. So only try Amlogic-ne nightly since 20240413 CE-21.
I am using the stable version of ne. I have reported it in the log. Before tonight, I was using the nightly version. Please give me your feedback. Thank you.
Did you try it with last nightly? PCI WiFi should now show up.
The bluetooth works correctly on ne/no, what doesn’t work is the wifi that can’t find any wifi point. (On Android it works correctly.)
1- Tried lasted available Nightly build?
YES
2- Device used?
T95w2 2/16 and dtb s4_s905w2_2g
3- Wifi/BT is working by using Amlogic-ng and or Amlogic-ne?
Wifi no and bluetooth yes.
4- SDIO Wifi SoC*
https://paste.coreelec.org/KVZZBP
5- dmesg:
https://paste.coreelec.org/jHBV7b
No driver is yet available for this chip.
dmesg | paste
https://paste.coreelec.org/KVABGK
Wrong DTB used
CoreELEC (official): 21.0-Omega_nightly_20240413 (Amlogic-ne.aarch64)
     CoreELEC dt-id: sc2_s905x4_kinhank_g1
https://paste.coreelec.org/Rpm0ws
Unknown device "/sys/bus/pci/devices/*": No such device
https://paste.coreelec.org/Lc9KkL
