New Order: Looking for users with no working WiFi or BT
You have still a dmesg from one of these boxes from Amlogic-ng?
https://paste.kodi.tv/imayodegib
20.4-Nexus_devel_20240301083248 ng
Same Tanix box as tht-3-2
Please reset tht-3.2 by power cycle. It should boot up normally, thx.
Turned it off via the power plug and plugged it back in it is up.
We need to stop investigate on 02D0:4330 chip. I can make only one test and then the device freeze again. So I think we continue next week with the devices with LAN issue. I will make a new nightly these days, please update to it and bring one or two devices up with LAN issue.
No problem will have them setup over the weekend
I have a couple new usb to ethernet adapters coming
should be hear on Saturday.
Was busy week at work
How is Progress on bcm 4339?
Have some free time now
Can enable t mate
What is access control Key ?
In settings?
Just leave access contol key set as user?
Sorry I don’t understand the question.
Nothing to do for this chip for now. No compatible driver exist. Maybe later one day.
In settings
Terminal sharing you will see
Enable terminal sharing
Send invitation to CoreELEC developers
Access control key
Connection name
Was wondering about control key
Is public/ private.
And if need to do anything or just leave as user
Does not matter now
As no driver for bcm 4339
https://wiki.coreelec.org/coreelec:term_share#establish_a_support_session
I will only be able to bring one of the Boxes online tonight, One of the usb to ethernet adapters
died shortly after installing it.
Waiting on a replacement.
@tht to the devicce tht-2, sm1_s905x3_4g_1gbit is a LAN cable connected to eth0?
For me it looks like no cable is connected:
eth0      Link encap:Ethernet  HWaddr 00:DF:12:00:9F:3D
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:37
Otherwise there should be some traffic at all, independent if it works or not.
All SM1 devices I have here have 1gbit connection and do have no issues.
It is connected and has a 169.254.14.31 at present
yes, now it’s connected and I see rx/tx packets. thx
We don’t find any reason why it should not work. Just reboot to Android and check if eth0 get an IP from DHCP? Maybe it’s something about the MAC?
This is what dmesg shows when running Android.
mac:6e:9a:01:f9:b2:15
fe80:85d9:586:496c:e875
10.0.0.160
[    0.000000] psci: probing for conduit method from DT.
[    0.794968] meson6-dwmac ff3f0000.ethernet: no reset control found
[    0.798814] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[    0.798822] eth%d: PHY ID 001cc916 at 7 IRQ POLL (stmmac-0:07)
[    0.801254] usbcore: registered new interface driver cdc_ether
[    0.807248] cpuidle: enable-method property 'psci' found operations
[    0.807384] cpuidle: enable-method property 'psci' found operations
[    0.807513] cpuidle: enable-method property 'psci' found operations
[    0.807639] cpuidle: enable-method property 'psci' found operations
[    1.145479] meson-g12a-pinctrl pinctrl@ff634480: pin GPIOZ_2 already requested by ff3f0000.ethernet; cannot claim for ff660000.audiobus:pdm
[    1.196810] EARC ff660000.audiobus:earc: Check whether support eARC TX
[    1.198851] EARC ff660000.audiobus:earc: Check whether support eARC TX
[    1.205498] EARC ff660000.audiobus:earc: Check whether support eARC TX
[    1.211971] EARC ff660000.audiobus:earc: Check whether support eARC TX
[    1.218671] EARC ff660000.audiobus:earc: platform get irq tx_cmdc failed, Check whether support eARC TX
[    1.228211] EARC ff660000.audiobus:earc: platform get irq tx_dmac failed, Check whether support eARC TX
[    1.244809] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.244920] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[   15.195260] eth0: device MAC address 6e:9a:01:f9:b2:15
[   15.279717] meson6-dwmac ff3f0000.ethernet eth0: fail to init PTP.
[   15.281791] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   18.358625] meson6-dwmac ff3f0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   19.158781] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
No idea why it doesn’t work. Try shorter or different cable?
Maybe better you bring up the device with 7668 chip online for tomorrow…
Well I swapped the cables and it still does the same thing.
I will put the 7668 Wifi chip box online for tomorrow
