g12b_s922x_odroid_n2plus
Can you post dmesg please? Just run and post url you get.
dmesg | paste
journalctl -l | paste
No worries
http://ix.io/3X1p (dmesg)
http://ix.io/3X1q (journalctl -l)
Ok, I can confirm the issue and will be resolved. Thanks for the cooperation.
Awesome, and thank you!
Please try next nightly.
All fixed here, thanks again!
A post was merged into an existing topic: Looking for users with no working WiFi or BT
In the last few versions not switch the resolution of Kodi via the web interface. A dialog box appears for confirmation after confirmation will the original resolution. But the resolution does not switch.
In the last Versions there is a tearing while watching video for a long time (mostly it appears after more than two hours).
At first the lower part ist a small line at the bottom of the screen then the bottom part grows (screenshot)
It does affect the gui too. The Output resolution is 2016p@50Hz, turning the GUI scaling on/off doesnāt make any difference.
http://ix.io/3XU6 (dmesg)
http://ix.io/3XU5 (journalctl)
ODROID N2+
I have one problem related to CEC - when it is on then OSD for sound is not showing up at all - no Volume up/down or mute. When it is off all is working the way it should. I can send log file if needed but should be easy to reproduce. Android box connected directly to Panasonic TV and then ARC from TV to Denon AVR.
On latest build and few before hevc seems to not work on 4k+, Iām loathe to downgrade to an older version as I have new set of addons that wotk with python 3. Is this a known issue? It doesnāt work at 1080p as well as 2160
You donāt specify what the specific symptoms of playback are and what device you are using.
Is the video going out through any external equipment?
If you are using new Inputstream Adaptive v.20.2.0 then itās a known issue
ISA V20.2.0 is for Nexus, V19.0.4 is for Matrix.
Latest Nexus Nightly has dumped me into Safe mode. Not sure why.
I have lately had the irritating issue in which video playback starts to stutter after pausing or right from the start. It is fixed by jumping back 10 seconds with the left arrow. I know that this is an old problem, but is there anything I could do to help debug it? Iām running the latest nightly on an ODroid N2, and HEVC encodes cause this at least (HW decoding enabled).
Iāve had the same problem for almost a year. I had the problem with stable, nightly, matrix, nexus, always with pure fresh install, no backup.
I have GT King. And always with ceemcc (i never tried sd card).
The āskip back 10 secondsā work around is so easy that i never bothered to solve it.
Yep I see this frequently too, also with HEVC/h265 stuff on N2/N2+ boxes.
i have installed 19.3 stable and this stuttering problem is gone.
