Week, if it is an important device, one every week without thumbs. You can delete old ones and keep three, outside the device, of course.
Hey there! Been using CoreELEC-Amlogic-ng.arm-20.0-Nexus_nightly_20221203 on my s905x4 (Vontar x4) with the sc2_s905x4_4g_1gbit device tree. Itās already working pretty stable aside from some networking issues, but Iām not able to get my xbox 360 wireless usb receiver up and running to use with my wireless controller(gamepad). It works under windows, showing a vendor/device id 045e:0291. Under the above mentioned nightly though, the device isnāt registered at all. No entries with lsusb, nothing in dmesg or the monitor function of udevadm. I loaded some kernel modules like xpad, but to no avail, the reciever just lights up or flashes. Been wrecking my brain over this for the last couple of days. If anyone knows what might be up, Iād like to hear it!
Thx!
I can“t seem to install PVR IPTV Simple. The PVR section under add-ons is completely missing. What can I do?
Edit: Hang on, hang on⦠am I in the right thread? I“m running the last Nexus nightly from yesterday on the N2+.
Try to force a repo update. There were some changes on addon server for the new Amlogic-ne project
Checked for updates manually several times already, even with āHide incompatibleā unchecked.
I came here to post the same situation of a missing PVR clients.
I am running the latest NE version on my HK1 rbox X4. I was trying to add a different skin, and the box locked up then finally rebooted. I am running the OS internally, when it rebooted, it wiped everything. There was something on the screen about boot into safe mode, but I did not take a photo of it.
I did have a backup on a different storage device, so right now I am trying to restore from my backup.
I am looking for the TVheadend PVR client. It was there and working until the box crashed and wiped everything.
Edit:. I found the PVR clients. It was listed under the coreELEC ADD-ONS. NORMALLY, I just use all repositories, I rarely click on the individual repository.
Sorry for hijacking this thread.
Is the me nightly still being updated or do we need to switch to another nightly such as ce 20
Same happened to me. Usually going to all repos and there wasnāt any pvr addons. When clicked on CE repo they pop in no problem. Nightly ng here on vontar x4 ![]()
I have a problem with the current nightly that I donāt remember the last SSH commands from the bash_history file.
on some movies, I have crashes when I advance a chapter. And I say well, of a chapter. Indeed, if I advance two or three, it passes and it does not crash. Odd. likewise, if I use fast forward, I manage to avoid the crash. In fact I donāt know if itās a coincidence, but I had this bug at the beginning on the Alpha of Vim4, and it disappeared after the next update. And a few days ago it came back.
Another thing, I have artifacts that sometimes appear, especially when a subtitle appears, the OSD appears, or a trailer embedded in the interface starts.
I have seen this error and itās kernel/mali blob issue as it can not open the DRM interface. This will need some more debugging.
Update your addons/skins:
2023-01-04 21:44:05.855 T:1867 warning <general>: Setting most video properties through ListItem.setInfo() is deprecated and might be removed in future Kodi versions. Please use the respective setter in InfoTagVideo.
2023-01-04 21:44:05.882 T:1867 warning <general>: ListItem.setUniqueIDs() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setUniqueIDs().
2023-01-04 21:44:05.882 T:1867 warning <general>: ListItem.setCast() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setCast().
the log is full of it and may cause a crash.
Thanks.
I donāt understand :
- Extensions auto-update is enabled.
- I checked my extensions and Addons one by one, and except display error, it seems that there is no more recent version.
- I canāt find the Addons you mention.
My Crash problem would be related to this according to you ? Should I find help on another forum so as not to pollute this one ?
On the other hand, the artifact problems would be linked to CoreElec?
Contact the author of the addon/skin.
Agreed, I will see on this side, thank you Portisch. But regarding visual artifacts (during subtitles, and during windowed trailers), what can I do? (I had this problem before installing this Skin)
Someone use a LePotato with CoreELEC on a 3840x2160 monitor ?
Iām stuck since long time on a older version. I can use LePotato in 1920x1080 with latest release just some 4k movie not start and stay on a black screen. When I change my resolution to 3840x2160 only mp4 work all other return me a black screen 2k/4k movie. Someone use LePotato ?
Thank you ![]()
Could CoreElec be ahead of Kodi and incorporate this feature ? Or does it just depend on the Kodi team ?
First at the media need to support it, second kodi must support it, third hardware (SoC) must support it, fourth kernel need to support itā¦
But maybe one day as 8K is just going to die and the devs get more time for such items ![]()
As indicated in the comments, beyond the media, it is above all the interface that would benefit from it, independent of the media.
- For transfers 60 fps (graphical interface) ā 24fps (movie).
- For the responsiveness AND the fluidity of the interface.
But thereās no rush, weāll wait for Kodi. Thanks.
My priority is to fix the occurrence of these crashes and visual artifacts. ![]()
I do not understand anymore. I even get errors when I try to upload my error logs, even this function throws errors, āFailed to generate logā : http://ix.io/4kVr
