running the latest nightly of NE 21 and the DialogPlayerProcessInfo.xml uses labels in the 316xx range that skins also use
Why i dont have popup on first boot of latest changelog when new update is installed. Im running latest ng 21 (20230504)
DD transcoding working ok for others on latest 21 -ne nightly?
4 posts were merged into an existing topic: Homatics Box R 4K Plus
Somthing is wrong with NG omega builds on my s905x3 android box (f3 air), from 20230704 and 20230705 i cant on longer play new media files that newer ben play before pressing play do nothing, only files that have resume play position work and finish files, going back to 20230702 fix problem
Update:
Using context menu and selecting ‘play’ option do nothing, but when you first select ‘play from here’ and then stop video after starts playing, and then you use ‘play’ option from context menu or button on remote, video starts to play normaly, but only that file all new never open files cant be play using play option on menu or button on remote (ir or kore or yatse)
Latest nighty 20231706 ng working perfectly on 2 boxes. One is an H96x2 , 2nd is X96x3. ![]()
Is new 20.3 nightly on Amlogic-ne incorporating the back port for DV support?
Where to download amlogic-ng-dv 20.3?
Nowhere. Release will be available with stable 20.3 release.
On this build https://relkai.coreelec.org/Amlogic-ne/ce-20/CoreELEC-Amlogic-ne.aarch64-20.3-Nexus_nightly_20230807.tar on the hk1 s905x4 iptv pvr simple client switch off with no compatible. How fix this bug?
Hello, just a tiny issue I’ve noticed since 2 or 3 weeks I am using CE on Homatics box (Dune HD). I’ve installed CE 20.2 nightly and box already updated couple times via auto update since. Despite the new build probably installed, I can still see 20.3-Nexus_Nightly_20230816 in CE addon as an OS version.
I guess it pulls the info from /etc/release:
Amlogic-ne.aarch64-20.3-Nexus_nightly_20230816
Is this a bug or my system has never been updated despite the message about new update was downloaded, asking me to reboot the box, which I did. How to find out CE version, running on the box?
Thank you.
Last one is 20230905:
https://relkai.coreelec.org/?dir=Amlogic-ne/ce-20
You see in /storage a file like update info where the last update process was saved.
Share this file please.
CoreELEC:~ # pwd
/storage
CoreELEC:~ # ls -la
total 29
drwxrwxrwx 16 root root 1024 Sep 5 09:58 .
drwxr-xr-x 13 root root 245 Aug 16 02:25 ..
-rw------- 1 root root 2442 Sep 4 15:41 .bash_history
drwxr-xr-x 16 root root 1024 Aug 28 10:43 .cache
drwxr-xr-x 18 root root 1024 Feb 16 2023 .config
drwxr-xr-x 7 root root 1024 Feb 16 2023 .kodi
drwxr-xr-x 13 root root 1024 Aug 26 14:05 .opt
drwx------ 2 root root 1024 Aug 28 11:40 .ssh
drwxr-xr-x 2 root root 1024 Feb 16 2023 .update
drwxr-xr-x 2 root root 1024 Sep 4 18:34 backup
drwx------ 2 root root 12288 Aug 16 02:26 lost+found
drwxrwxrwx 2 root root 1024 Feb 16 2023 music
drwxrwxrwx 2 root root 1024 Feb 16 2023 pictures
drwxr-xr-x 2 root root 1024 Sep 5 09:58 pub
drwxrwxrwx 2 root root 1024 Feb 16 2023 screenshots
drwxrwxrwx 2 root root 1024 Feb 16 2023 tvshows
drwxrwxrwx 2 root root 1024 Feb 16 2023 videos
CoreELEC:~ # ls -la .update/
total 2
drwxrwxrwx 16 root root 1024 Sep 5 09:58 ..
CoreELEC:~ #
Then something is broken for you, there should be a init-previous.log or init.log file.
Try clean fresh install.
is this log created also during automatic upgrade or during manual upgrades only? by “manual” I mean copying *.tar (or whatever image file) into /storage/.update and reboot as this is something I haven’t tried yet.
I only experienced 2 automatic upgrades/updates (probably to newer build rather than release) when Kodi popped up with message about newer downloaded image and asked me to reboot the box. Which I did, but I can still see 20230816 and no log in /storage.
CoreELEC:~/.update # find /storage/ -name init*.log
edit: it’s interesting I am not the only one with this. I know about two other users running same box, same release and no nightly updates. They did only manual upgrades by copying image into the /storage/.update folder.
well, I just did manual update by wgetting 20.3-Nexus_nightly_20230905 into /storage/.update. Rebooted box and now I can see correct version in CE addon. Kodi also popped up with release notes and I can see init-previous.log that hasn’t been the case during “previous updates”. So I guess my box has never already updated previously.
Interesting I know about two more users experiencing very same issue on Homatics/Dune HD box with CE 20.3
I am curious if new nightly builds will install automatically from now on.
It’s easy to test it. Just install the previous nightly and see if it install the today’s one.
I am happy box is working, so I guess I rather be patient and wait on 20230905 until the next nightly build. : )
