Nightly builds (NEW)
Recommend 20.5-ng nightly vs 21. More stable DV playback.
It seems as if the FEL issues have largely been resolved if you want to test it out.
Oh! thank U. It’s very kind of U. I’ll try.
Using NE 21 20240405
Speedtester stopped working. 1.1.2 from ce addon directory.
Was ok on prev version.
Edit:
This one seems to work ok.
script.speedtester-1.1.3+matrix.1.zip (1.5 MB)
For some versions now (since 20.x), I’ve had the issue where my video and music libraries go missing if I reboot the box. Rebooting the box again will not help, only restarting Kodi while running rediscovers the library. I can also make Kodi crash if the library is missing, I go to the video source and try to launch some movie. After the crash, Kodi restarts and the library is back.
I’m not 100% sure if this has something to do with my NAS hard drives waking up when they are accessed, but the database connections mentioned in these logs attempts to connect to my PC and not the NAS. I’m also wondering why it’s trying to access so many versions of the DB.
Any ideas what to start looking at? This is a bit cumbersome because it happens every time I update to a new build.
2024-02-27 19:26:18.943 T:1435    error <general>: Unable to open database: MyVideos131 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.943 T:1435    error <general>: Unable to open database: MyVideos130 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.943 T:1435    error <general>: Unable to open database: MyVideos129 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.943 T:1435    error <general>: Unable to open database: MyVideos128 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.943 T:1435    error <general>: Unable to open database: MyVideos127 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.943 T:1435    error <general>: Unable to open database: MyVideos126 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.943 T:1435    error <general>: Unable to open database: MyVideos125 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.944 T:1435    error <general>: Unable to open database: MyVideos124 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.944 T:1435    error <general>: Unable to open database: MyVideos123 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.944 T:1435    error <general>: Unable to open database: MyVideos122 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.944 T:1435    error <general>: Unable to open database: MyVideos121 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.944 T:1435    error <general>: Unable to open database: MyVideos120 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.944 T:1435    error <general>: Unable to open database: MyVideos119 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.944 T:1435    error <general>: Unable to open database: MyVideos118 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.945 T:1435    error <general>: Unable to open database: MyVideos117 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.945 T:1435    error <general>: Unable to open database: MyVideos116 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.945 T:1435    error <general>: Unable to open database: MyVideos115 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.945 T:1435    error <general>: Unable to open database: MyVideos114 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.945 T:1435    error <general>: Unable to open database: MyVideos113 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.945 T:1435    error <general>: Unable to open database: MyVideos112 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.945 T:1435    error <general>: Unable to open database: MyVideos111 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.946 T:1435    error <general>: Unable to open database: MyVideos110 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.946 T:1435    error <general>: Unable to open database: MyVideos109 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.946 T:1435    error <general>: Unable to open database: MyVideos108 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.946 T:1435    error <general>: Unable to open database: MyVideos107 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.946 T:1435    error <general>: Unable to open database: MyVideos106 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.946 T:1435    error <general>: Unable to open database: MyVideos105 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.946 T:1435    error <general>: Unable to open database: MyVideos104 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.947 T:1435    error <general>: Unable to open database: MyVideos103 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.947 T:1435    error <general>: Unable to open database: MyVideos102 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.947 T:1435    error <general>: Unable to open database: MyVideos101 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.947 T:1435    error <general>: Unable to open database: MyVideos100 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.947 T:1435    error <general>: Unable to open database: MyVideos99 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.947 T:1435    error <general>: Unable to open database: MyVideos98 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.947 T:1435    error <general>: Unable to open database: MyVideos97 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.948 T:1435    error <general>: Unable to open database: MyVideos96 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.948 T:1435    error <general>: Unable to open database: MyVideos95 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.948 T:1435    error <general>: Unable to open database: MyVideos94 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.948 T:1435    error <general>: Unable to open database: MyVideos93 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.948 T:1435    error <general>: Unable to open database: MyVideos92 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.948 T:1435    error <general>: Unable to open database: MyVideos91 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.948 T:1435    error <general>: Unable to open database: MyVideos90 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.949 T:1435    error <general>: Unable to open database: MyVideos89 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.949 T:1435    error <general>: Unable to open database: MyVideos88 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.949 T:1435    error <general>: Unable to open database: MyVideos87 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.949 T:1435    error <general>: Unable to open database: MyVideos86 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.949 T:1435    error <general>: Unable to open database: MyVideos85 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.949 T:1435    error <general>: Unable to open database: MyVideos84 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.949 T:1435    error <general>: Unable to open database: MyVideos83 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.950 T:1435    error <general>: Unable to open database: MyVideos82 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.950 T:1435    error <general>: Unable to open database: MyVideos81 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.950 T:1435    error <general>: Unable to open database: MyVideos80 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.950 T:1435    error <general>: Unable to open database: MyVideos79 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.950 T:1435    error <general>: Unable to open database: MyVideos78 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.950 T:1435    error <general>: Unable to open database: MyVideos77 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.950 T:1435    error <general>: Unable to open database: MyVideos76 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.951 T:1435    error <general>: Unable to open database: MyVideos75 [2002](Can't connect to server on '192.168.0.50' (101))
2024-02-27 19:26:18.951 T:1435    error <general>: Unable to open database: MyVideos131 [2002](Can't connect to server on '192.168.0.50' (101))
Just installed nightly 20240522 on an Ugoos AM6B+, and when selecting information provider for one of my media sources I notice the the ā€œGet moreā€¦ā€ button is missing (it’s present and correct on my 21 stable box). I have a long history of using The TVDB and went to install via ā€œGet moreā€¦ā€ as usual but the button isn’t there.
Ugoos CE 21-NG last nightly devel…
interesting, what might the explanation be? I downloaded the nightly just a few hours ago.
I use the last devel, which included the last nightly…
not sure what to do next. This was a clean install, using the build from the main nightly page, accessed a few hours ago.
If there’s no get more there’s not Internet connection…
thanks for the tip, that gave me a lead. The Ugoos I set up today was the second in a few weeks, this one had a slightly glitchy network setup with finding my MariaDB database on the NAS, but got there in the end and I was able to play content over my LAN. But clearly the wired connection to my main switch was a bit flaky as I then lost the library on a reboot. I restarted the wired connection and all seems good now. Perhaps the physical connection was not quite right.
Thanks to the CoreELEC team ,
Ugoos AM8 new kernel dtb has been added but it won’t boot with the new dtb.Constantly rebooting with new dtb
ā€œCoreELEC-Amlogic-no.aarch64-22.0-P_nightly_20240730-Genericā€
Ugoos AM8 and other S928X devices will not boot NO yet. Work in progress.
Thank you, good work.
Thanks, AM8 is booting today with the software provided.
First observations.
1-Wireless does not work.
2-4K videos and 4K live TV do not work.(Black screen)
3-Color distortion in all videos due to Dovi.ko kernel incompatibility
Note: TV tested with normal 1080P.
Best regards…
work in progress
there is no DV with this image
Thank you CE team, AM8 is working wireless with nightly version released today.
ā€œCoreELEC-Amlogic-no.aarch64-22.0-P_nightly_20240801-Generic.imgā€
Is there a sound? I only have Bluetooth output being tested.
The last normally working 20240729, which is supposedly broken. I roll back on it all the time.
Hi @vpeter my nightlies auto update always 2/3 mb short i.e~253mb, so file ends up corrupt. Would logs show this?
P.s. i regularly interchange between the cube 2nd gen & minix u22-xj max.
