I’m happy to chip in. I’m running a um6b+ connected to my Yamaha 3070. Output from the amp is to my LG 77 C9. I have absolutely zero lip sync issues on any file. Almost all of my library are remuxes ranging from blu rays to ultra hd Dolby vision profile 7 and 8.
The problem could be anywhere in your AV chain. It’s not necessarily anything to do with CoreELEC
Ugoos am6b plus with nightly_20241026 FEL TEST DT DL P7 CMV4.0 4000nits V3.mp4 seem like FEL layer not working anymore… But downgrade to nightly_20241021 seem to be fine.
Then from here download appropriate version, copy it to storage/.update folder and reboot.
CMV2.9 FEL also broken. How do I roll back to the previous nightly?
Download the one from yesterday here
And put the file in the .update folder, and reboot
I’ve went back to 21.1.1 from the device updater. Will I get offered the next nightly when it comes out?
For FEL: video and video/audio timing component must be enabled.
Samples?
The FEL test files from this page show the issue. I’ve rolled back and they’re playing fine on 21.1.1
Not sure what’s going on but Ive just downloaded the 25/10 nightly and the fel sample file played fine. I’d forgotten to turn off the auto updater and it auto installed 26/10 nightly which previously caused issues. For some reason the FEL files played just fine this time round.
Is there any possible reason why going from 21/10 to 26/10 (I had the same upgrade path as the other poster) caused a FEL playback issue but going from 21.1.1 stable to 25/10 to 26/10 causes no issue? :-/
Yes. Same way I’ve upgrade from 21/10 to 26/10 [ Skip 25/10 ] after that FEL DL-DT no longer working. for now I just downgrade to 21/10 so far no issue all FEL play fine.
I found a newly released P7-MEL MKV film that has a lot of issue seeking with chapter and resuming. I have never seen this on any other MEL MKV in my library. Seek/resume actions will sometimes crash the player. If it doesn’t crash, it will take ~20s to resume. It also for the first time I can remember, caused an HDMI dropout on my LG G2.
This is tested on 10/26 nightly. Below is dmesg and log:
dmesg
https://paste.coreelec.org/CreamedOperated
log
https://paste.coreelec.org/PullsQuarters
MediaInfo:
Format : Matroska
Format version : Version 4
File size : 70.5 GiB
Duration : 2 h 0 min
Overall bit rate mode : Variable
Overall bit rate : 83.8 Mb/s
Frame rate : 23.976 FPS
Movie name : A Man for All Seasons (1966)
Encoded date : 2024-10-26 16:57:29 UTC
Writing application : mkvmerge v88.0 ('All I Know') 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
IMDB : tt0060665
TMDB : movie/874
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 77.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.388
Stream size : 64.9 GiB (92%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 2000 cd/m2
Maximum Content Light Level : 2139 cd/m2
Maximum Frame-Average Light : 126 cd/m2
Source : Sony Pictures USA UHD Blu-ray (2024)
Audio #1
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Bit rate mode : Variable
Bit rate : 243 kb/s
Channel(s) : 1 channel
Channel layout : M
Sampling rate : 48.0 kHz
Frame rate : 11.719 FPS (4096 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Stream size : 209 MiB (0%)
Title : Original Mono Mix
Writing library : libFLAC 1.4.3 (2023-06-23)
Language : English
Default : Yes
Forced : No
MD5 of the unencoded conten : 8D450040B7E10C50EB61D60640F5E7B8
Audio #2
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate : 3 852 kb/s
Maximum bit rate : 5 478 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Frame rate : 1 200.000 FPS (40 SPF)
Stream size : 3.24 GiB (5%)
Title : Surround Upmix / Dolby Atmos 7.1
Language : English
Default : No
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 552 MiB (1%)
Title : Surround Upmix / Compatibility Track
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #4
Format : FLAC
Codec ID : A_FLAC
Bit rate : 462 kb/s
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 399 MiB (1%)
Title : Commentary by film historians Nick Redman, Lem Dobbs and Julie Kirgo
Language : English
Default : No
Forced : No
Source : Twilight Time USA Blu-ray (2015)
MD5 of the unencoded conten : 588D1FB08C1F1AB0B7FF6200C3B187F9
Audio #5
Format : FLAC
Codec ID : A_FLAC
Bit rate : 317 kb/s
Bit depth : 24 bits
Stream size : 273 MiB (0%)
Title : Isolated Score
Language : zxx
Default : No
Forced : No
MD5 of the unencoded conten : A077503B31749933E2F5B281FB107C2F
Menu
00:00:00.000 : en:Start
00:05:15.732 : en:A Butcher's Summons
00:09:29.653 : en:With the Cardinal
00:16:13.973 : en:Petitions
00:17:13.992 : en:Home to Chelsea
00:22:21.757 : en:Saying "No" to a Heretic
00:26:28.796 : en:The Duke of Norfolk
00:27:51.503 : en:The New Lord Chancellor
00:29:18.507 : en:"Surprise" Visit
00:34:41.788 : en:Quiet Words
00:43:02.455 : en:Catching the Tide
00:47:15.500 : en:A Bad, Dangerous Spy
00:50:38.077 : en:Rich & the New Secretary
00:55:08.681 : en:The King's Answer
00:56:28.677 : en:More Resigns
00:58:05.357 : en:Explaining His Decision
01:10:11.708 : en:The King's Wedding Day
01:12:49.198 : en:A Letter
01:13:56.474 : en:Conversation With Cromwell
01:19:03.781 : en:Ending a Friendship
01:24:01.704 : en:News of the Oath
01:25:39.259 : en:In the Tower
01:28:12.996 : en:An Inquiry
01:35:34.521 : en:Family Visit
01:43:31.789 : en:The Trial
01:49:45.287 : en:Richard Rich Testifies
01:54:07.257 : en:Verdict & Discharge
01:57:55.986 : en:Sentence Carried Out
Sample (10min)
DV FEL broken on my Am6b+ too in nightlies from Oct 25th and 26th.
Downgraded to nightly from Oct 17 and it’s working fine again.
It looks like it is partially broken.
The STDL FEL mp4 still works, but the DTDL version does not on 10/26 nightly.
These:
https://drive.google.com/drive/u/0/folders/1V-onFW4PwgKAFdVlwXeuKOnUvdZXqsY6
Yeah I thought I had it working on 26/10 (see post above) but I noticed a film I was watching last night had muted colours. I checked the fel test files I had and a couple passed whereas one didn’t. I rolled back to 25/10 and I got the same. I then rolled way back to the nightly I used to set up at the beginning of October and everything was fine again. I’ve just disabled updates now. I don’t really need any more development from coreelec on my AM6B+ and I’m not convinced that maintaining FEL support is a priority for the developers.
DV FEL still broken in today’s nightly. I enabled debugging and the audio/video timing component and played the DTDL test sample which is now not showing the FEL layer. Unfortunately, I’m getting failed error when trying to upload the log…
Thanks for checking and reporting!
