Nightly builds (NEW)
CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20260612
Ugoos AM9 Pro with CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20260618.tar
UR02 Ok button not works right.
The OK button opens a menu where nothing works. So I cant start PM4K Addon. But the OK button still works with mouse control.
Have to go back to CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20260617.tar
I second that, 20260618 messed up remote OK button on my AM6B+ and weird HDMI connection as playing a video once starts TV switches input automatically.
back to 20260617
will be fixed tomorrow
UR02 All the buttons on my remote control are working.
I’m using the remote.conf and gen.xml files.
With today’s nightly ā€œCoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20260619ā€ the UR02 remote (bluetooth) works very badly. Only very few buttons work properly, many do not respond to the command. This affects UR02 for AM9 Pro, my friend’s SK4 and also the Homatics box R 4k plus remote (bluetooth)
Back to nightly ā€œCoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20260617ā€ and everything works properly.
The same problem applies to the AM6B+ as well (bluetooth)
Only Enter/OK button behaviour was changed and not any other.
Maybe related to this: add support for some new multimedia keys by oliver Ā· Pull Request #27932 Ā· xbmc/xbmc Ā· GitHub
OK button fixed partialy, does work as intended excepte while on the player, it does not open the UI as usual. On 22.0-Piers_nightly_20260619
I had a similar issue recently on my Tox3. I just remapped a couple of keys using Kodi key mapper to fix them. I just copy Gen.xml into any updates I do.
Test image for fix OK button on remote under fullscreen video: https://test.coreelec.org/vpeter/CoreELEC-Amlogic-no.aarch64-22.0-Piers_devel_vpeter_remote_ok_fix.tar
Remove/disable any other workarounds.
Your build works as intended. OK button now works properly. Thank you.
And CE 22 is getting better and better in picture quality, audio sync, speed and fast response.
Congrats to CE Team, you are building a real winner.
And AM9 Pro shines.
Thank you all.
:smiling_face_with_three_hearts: :smiling_face_with_three_hearts: :smiling_face_with_three_hearts:
OK button on BT remotes should work again with build 20260622. Tested B21 and UR02.
Hi
I’m reporting a video decoding issue encountered on the latest 22.0-Piers_alpha3 build.
My Hardware Setup:
  • Device: Minix NEO U22-XJ (S922X-J)
  • OS: CoreELEC 22.0-Piers_alpha3 (Amlogic-NO architecture)
Issue Description:
When using the iPlayer WWW add-on, the video stream completely freezes a few moments after playback starts, while the audio track continues to play flawlessly in the background.
Troubleshooting Steps Already Attempted (with no change):
  1. Adjusted GUI resolution from 23Hz to 50Hz to match the native stream format.
  2. Swapped InputStream Adaptive cache settings (tested 128MB, 64MB, and system defaults).
  3. Reinstalled Widevine CDM
  4. Disabled AMCODEC hw acceleration
I have generated a clean debug log immediately following the freeze:
Debug Log zip attached.
Any help or insight
kodi.zip (1.6 MB)
would be greatly appreciated. Thanks!
No one will check on this version. Try with latest nightly.
OK well it was the latest nightly 21-06-26 when I posted on 21-06-26 but here’s this morning’s log with the latest nightly. The video froze at 09:34 UK BST.
kodi.zip (1.6 MB)
DON’T upload zips, use CoreELEC debug system and paste debug link.
Upload will just be removed and not checked.
Perfect. Both works. Thanks
I’m reporting a video decoding issue encountered on the latest 22.0-Piers_alpha3 build (22.0-Piers_nightly_20260622).
My Hardware Setup:
Issue Description:
I have generated a clean debug log immediately following the freeze (at 22-06-26 15:59). The freeze is generally reproducible after a few minutes of stream playback. Not sure whether the crash log is appropriate so I’ve included both URLs generated.
https://paste.coreelec.org/TickledStork
https://paste.coreelec.org/SedleyMiramax
Any help or insight would be greatly appreciated. Thanks!
Today I with the AM9 Pro and my friend with the Sk4 had the same problem. Watching a movie (not the same movie and not watching at the same time) suddenly at about 35 mins. the box restarted, Tried on different movies, even sdr, and this happened afte about 30/40 mins.
Don’t know what caused this on both boxes nor can do any logs.
I am aware that @Portisch asks for some logs, that are impossible to get because this reboot happens without notice.
I want to inform you of this problem, that’s all.
Thank you.
Nightly build 06/22
