The “paste” command didn’t work, this is the output:
X96Max:~ # mount >/tmp/peter.log
X96Max:~ # echo >>/tmp/peter.log
X96Max:~ # cat /proc/cmdline >>/tmp/peter.log
X96Max:~ # paste /tmp/peter.log
502 Bad Gateway
502 Bad Gateway
nginx
X96Max:~ #
X96Max:~ # cat /tmp/peter.log
devtmpfs on /dev type devtmpfs (rw,relatime,size=1013756k,nr_inodes=253439,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
/dev/CE_FLASH on /flash type vfat (ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/loop0 on / type squashfs (ro,relatime)
/dev/CE_STORAGE on /storage type ext4 (rw,noatime,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/debug type cgroup (rw,nosuid,nodev,noexec,relatime,debug)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /var type tmpfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
GDrive-Crypt: on /storage/google-drive-crypt type fuse.rclone (ro,nosuid,nodev,relatime,user_id=0,group_id=0)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xff803000 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 otg_device=0 reboot_mode_android=normal logo=osd0,loaded,0x3d800000 vout=1080p60hz,enable panel_type=lcd_1 hdmitx=,444,8bit hdmimode=1080p60hz frac_rate_policy=1 hdmi_read_edid=1 cvbsmode=576cvbs osd_reverse=0 video_reverse=0 irq_check_en=0 androidboot.selinux=permissive androidboot.firstboot=0 jtag=disable androidboot.hardware=amlogic androidboot.serialno=1234567890 mac=90:0e:b3:11:a0:91 androidboot.mac=90:0e:b3:11:a0:91 androidboot.rpmb_state=0 BOOT_IMAGE=kernel.img boot=LABEL=CE_FLASH disk=FOLDER=/dev/CE_STORAGE console=ttyS0,115200 console=tty0 no_console_suspend hdmimode=1080p60hz logo=osd0,loaded,0x3d800000 quiet console=tty0 systemd.show_status=auto
Thanks for your help.
Regards.
