Bluetooth regression.
Although the BT adapter is recognised and connecting functions displayed for Devices, none of the three headsets I tried would hold a connection.
I reverted to yesterdayâs .tar and BT is working as expected.
This option wasnât available in my config.ini, while Iâm on the latest nightly.
There was only hdmi_cec, and Iâve set this to 0, and added cec_func_config=0 as well.
Now, the box is not waking up anymore, which is good. Is there a way to have the TV turned of when I turn off the box? So, sort of one way communication? The TV canât wake up/power down the box, but the box van wake up/power down the TV?
Iâve enabled the CEC adapter again in the CoreElec settings, but the TV is not powered off when I suspend/power off the box.
Thanks!
GT King Pro does not receive IP from time to time. The IP it receives is as follows 169.254.26.229 - 169.254.87.194. Tvheadent is disabled and the channel cannot be changed.The same problems occur with Pvr IpTv Client.CoreELEC does not work in the settings menu.
My device is used with this usb tuner TBS5520SE.
Hi, since I installed nightly_20200213 sometimes this message appears when CoreELEC starts. I have not seen this message before.
I use odroid N2 and I have never enabled the bl301 tool.
update-bl301.service - CoreELEC BL301 Update Service
Loaded: loaded (/usr/lib/systemd/system/update-bl301.service; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2020-02-14 22:13:50 CET; 18min ago
Process: 3375 ExecStart=/usr/lib/coreelec/update-bl301 -v (code=exited, status=1/FAILURE)
Main PID: 3375 (code=exited, status=1/FAILURE)
Feb 14 22:13:50 CoreELEC systemd[1]: Starting CoreELEC BL301 Update Service...
Feb 14 22:13:50 CoreELEC update-bl301[3375]: CoreELEC BL301 not installed
Feb 14 22:13:50 CoreELEC systemd[1]: update-bl301.service: Main process exited, code=exited, status=1/FAILURE
Feb 14 22:13:50 CoreELEC systemd[1]: update-bl301.service: Failed with result 'exit-code'.
Feb 14 22:13:50 CoreELEC systemd[1]: Failed to start CoreELEC BL301 Update Service.
I also noticed that something is wrong with the suspend mode. Sometimes when the suspend mode is activated, the red led is still on and I canât restore kodi from sleep.
Vim3L Just updated to 13th February
Fixed my issues with the one MUX in all HD channels.
Now correct PC1 and no jitter / micro stutters.
Perfect Playback.
For ondemand governor I used this
#!/bin/sh
echo âondemandâ > /sys/devices/system/cpu/cpufreq/policy0/scaling_governor
in autostart.sh. it works fine, but I donât know if itâs the right way.
Is there any setting in the coreelec menu to switch between performance and ondemand governor?
thanks.
I am just wondering whether the experts have the scaling problem âsdr to hdrâ on the screen or whether I should continue to report this? greetings and a nice weekend
